C63 AMG (W204) 2008 - 2015
Did anyone here insulate their garage for warmer cold starts?
Old May 12, 2019 | 04:31 PM
NotABaller's Avatar
2012 C63, 2014 E550
Just bought a house, have been living in a condo with heated garage until now.
Here in Canada my car’s oil temp is near zero Celsius when cold starting in the winter. I’m really worried about this, since I park outside for work too.
So my car car will have to cold start twice a day at nearly 0 degrees oil temps. Did anyone insulate/heat their garage to keep their cars warm?
Thanks!!
Old May 13, 2019 | 08:46 AM
Funkwagen's Avatar
2009 C63 AMG, 2010 C250 4Matic Sport
If you have access to an electrical outlet you already have a block heater installed in the coolant lines. The connecting cable is about $40 from the dealer. It's not the most elaborate heater, it doesn't pump coolant, but its just a heat element in the block that will definitely speed up warm up time on cold start
Old May 13, 2019 | 09:45 AM
NotABaller's Avatar
2012 C63, 2014 E550
Thanks, will look into this. So my car will look like a plugin hybrid when parked at my garage I guess? Is my imagination correct?
Also, does anyone know how bad cold starts at 0-10c oil temp are? I have to do this twice a day in winters, and I plan to keep my car for a very long time. Would do anything within reason to mitigate the damage caused by this.
Old May 13, 2019 | 10:05 AM
NotABaller's Avatar
2012 C63, 2014 E550
Just googled and it does look like something I plug in. Does it heat up coolant as well as oil?
Old May 13, 2019 | 01:12 PM
Jasonoff's Avatar
Top Answer: 3
2010 C63 AMG
Fully insulated and heated. I have found 13.5°C is the perfect temp to keep it at.
Old May 13, 2019 | 03:23 PM
Kriston's Avatar
C63 AMG
I think this car is causing you too many issues, maybe revert back to stock. Take the headers off. The car is fine starting at 0 degrees, its a car man..... do all of the other cars in Toronto have issues starting in minus 0 degree temps?
So heres your solution:
If car too loud - take off headers
If car too slow - Super Charge it
If Super Charge too much - Sell Car
Easy breezy.....
PS: I have always felt 11.3095890 Degrees C is the best temp to get the car to warp speeds.
Old May 13, 2019 | 03:27 PM
NotABaller's Avatar
2012 C63, 2014 E550
Easy breezy.....
Great, thanks for your input
Old May 13, 2019 | 04:31 PM
Jasonoff's Avatar
Top Answer: 3
2010 C63 AMG
I wasn't joking about the temp setting lol
Old May 13, 2019 | 04:36 PM
Kriston's Avatar
C63 AMG
But "Warp Speed" ready?
Old May 13, 2019 | 04:55 PM
Jasonoff's Avatar
Top Answer: 3
2010 C63 AMG
Amateur hour...
Old May 13, 2019 | 04:58 PM
BLKROKT's Avatar
2012 P31 C63 Coupe Trackrat, 2019 GLE63S Coupe Beast
Originally Posted by Jasonoff
Amateur hour...
Pffffft. Who’s the amateur now.
Old May 14, 2019 | 01:32 PM
Mort's Avatar
I heat my garage to 10C, just saying.
Insulate and heat your garage to 10C, Your wife will thank you, your kids will thank you, your car(s) will thank you and you will thank you.
Old May 14, 2019 | 01:36 PM
NotABaller's Avatar
2012 C63, 2014 E550
Thanks for the serious reply!
Old May 14, 2019 | 02:12 PM
Mort's Avatar
Welcome!
Old May 15, 2019 | 12:43 PM
Mully78's Avatar
2013 C63 PP Sedan
I keep mine at 10C as well Mort. Must be a Maritimes thing
