MCT Clutch Slip - still unresolved?
My story: 2012 Performance Pack Coupe, with 120,000km, zero modifications.
There's clutch slip with momentary engine speed flare in every gear when accelerating from under 2000rpm, in all transmission modes. There is ZERO slip above 2000rpm.
With standing starts from 1st gear at moderate throttle the transmission hooks up without slip ( probably because engine speed rapidly ascends beyond 2000rpm), but there's a judder which feels similar to "old school" axle tramp ( but clearly isn't).
Dealer has performed the following:
Checked fault codes - none
Updated to latest software - no impact
Performed re-adaptation - no impact
Carried out smoke test for inlet manifold issues - very minor leak. Corrected - no impact
Replaced entire clutch pack and clutch solenoid valve - FIXED!!! But 5000km later, it's back, as bad as ever.
For what it's worth, I mostly drive in manual mode, except in heavy traffic. Aside from clutch slip, all changes are rapid - there's no delay in response to paddles.
Any thoughts on this incredibly annoying ( and costly!) issue??
For me it's a very, very disappointing outcome. This is the only car I have ever kept for more than 5 years, because I still love driving it. I had made up my mind to keep it indefinitely, because a meticulously well maintained and cared for Merc V8 should last a long time, right? I saw myself down the track as "that old guy with 400,000km on his Benz". The last of the great NA V8's etc etc.
Multiple costly failures in recent years now have me seriously doubting this plan.
Also, surely you could source a new transmission for less yourself... Or buy a built one for nearly the same price they are asking. Is this all being done under warranty?
I doubt it’s possible to buy and install a new MCT for anything like this money, but I may be wrong.
No warranty unfortunately- car is nearly 8 years old.
Can't rule out a defect from the factory I guess, but I suspect not as the transmission was perfect right up to 120,000km when the fault became apparent.
Once warm/hot it shifts fine at all times.
I had the oil changed 2018 and have travelled around 15,000 klm.
It has been suggested that maybe the fluid level is a little on the low side but once hot its fine due to expansion of the trans fluid.
