C63 AMG (W204) 2008 - 2015
Time to Stir the Pot...M156 Airbox Content
Old Jun 24, 2019 | 01:54 PM
BLKROKT's Avatar
2012 P31 C63 Coupe Trackrat, 2019 GLE63S Coupe Beast
Originally Posted by hachiroku
i spent 52 dollars and labor, and will have a lot of excess material...that is a huge difference to the 350+ for the OEM ROW airboxes.
Originally Posted by VictoryRoadPerformance
We are going to offer a coupon code for everyone in this thread, save yourself the hassle and potential damage to your engine. Use coupon code
MBWORLDROW and get the Inserts for $150
You should jump on this deal. Agree that using JBWeld anywhere in your intake post-filter isn’t a great idea.
Old Jun 24, 2019 | 03:06 PM
hachiroku's Avatar
SPONSOR
2007 Mercedes E63 AMG
Plastic Bonder is a quick-setting, two-part, urethane adhesive system that provides strong and lasting repairs and works on thermoset, carbon fiber composites, thermoplastics, coated metals, concrete & more. Plastic Bonder has a 1:1 mixing ratio, sets in 15 minutes and can be sanded after 30 minutes. With a tensile strength of 3770 PSI, Plastic Bonder sets to a tan color and cures to a hard, permanent bond.
with only 1 coating and the stainless steel support structure its already very rigid plastic. i plan to add on 3-4 more layers and shape. will be stronger than the original part. i understand the hesitation...i had hesitation as well. it took me this long to jump on the project because of that, but then i learned about their plastic product. after through research and speaking to JBWELD over the phone it gave me complete confidence.
with the new discount offered by VRP...they are a solid option at that price point. highly recommended.
__________________
-BARRY
​​​Follow us on instagram @eightysixtuned
https://www.eightysixtuned.com
Old Jun 27, 2019 | 01:52 PM
HLG600's Avatar
2009 SL63 AMG
Now that's a proper /Thread. Ordered.
Old Jul 22, 2019 | 03:23 AM
hachiroku's Avatar
SPONSOR
finally got off my ***...now to figure out what to do about the steel insert missing a section of metal which could allow some air to bypass...the proper thing to do would be to have someone TIG weld some sheet steel in place. I assume those steel sleeves from the ROW boxes are not available separately? even with replacement horns, you'll run into this issue or an issue with the metal needing to be shaved back as they'll hamper airflow. really depends on how you flip and insert the steel sleeves.
maybe I'll seal up the air horns with RTV Gasket and wipe off the excess so it's pretty much air tight with no chance of gasket material sucking the whole way though? I'll have to take a look tomorrow and see what we're working with. I'll also seal up behind the steel sleeve if that's the case if I proceed.
I am pretty happy with how it turned out. 9/10 of what I envisioned...only subtracted a point because there were some spots where I got lazy and buzzed off a little bit too much material. oh well...here it goes.
are ROW air boxes better...yes...yes they are...but I wanted to try making replacement air horns and was able to so there's that.
Old Jul 23, 2019 | 08:35 PM
hachiroku's Avatar
SPONSOR
don't recall what the W211 North American airboxes look like before modifications but here is what the W212 boxes I was using for the meantime.
Old Mar 10, 2022 | 08:09 PM
sciroccor's Avatar
2007 e63 estate, 1998 ITB golf, ITE scirocco (sold to a collector in Japan)
I think this is what youre looking for...
https://vrpspeed.com/product/rowins/
Printed in Carbon Fiber-Nylon
Customer submitted install photos:
that's a pretty good job. nice innovation. they aren't available, though.
