C63 AMG (W204) 2008 - 2015
part number of headlight bracket for c63 2009
Old Jun 25, 2019 | 08:45 AM
mhammadkassem's Avatar
C200 kompressor 2001
hello guys i had a car accident with my c63 and sadly the headlight bracket gor broken i wwnted to get a new one but its too expensive as i tried to get a used one i couldnt find the same part number as the new one and the most confusing issue is that the one i had before the accident happened has also a different part number.
The part number of new bracket is A 204 620 06 91
The part number of my old broken bracket is A 204 620 14 14
The part number of the used bracket i found is A 204 626 30 46
I called mercedes official dealer and they couldn't recognize the other 2 part numbers can anyone please explain this thing !!
Old Jun 25, 2019 | 01:30 PM
Valvestud's Avatar
2014 E63 AMGs, 2015 F-150 Lariat, 2010 Porsche C4S
See if you pick out part from the attached file.
Old Jun 25, 2019 | 01:38 PM
no the part i want is ot listed here ... this is the part i want
check the link
https://www.mboemparts.com/oem-parts...ame-2046200691
Old Jun 25, 2019 | 02:06 PM
Valvestud's Avatar
check the link
It's in the attached.
Old Jun 25, 2019 | 02:13 PM
yes i know this is supposed to be the correct part number but the confusing thing is that the one i had on my car had a different part number (204 620 14 14) and when i searched for it in used spare parts they gave me one with also different part number (204 626 30 46) ...any idea about these part number?
Old Jun 25, 2019 | 02:17 PM
Valvestud's Avatar
Neither of those numbers are valid in MB system. Please remember that numbers on a part are not necessarily the actual part number.
Old Jun 25, 2019 | 02:20 PM
what do u mean by numbers are not the actual part number? check the photo i attached it has the part number A 204 626 30 46 ...how can i make sure if it fits my c63 ?
Old Jun 25, 2019 | 02:23 PM
Valvestud's Avatar
There is no way to verify that it will fit. Numbers stamped on a part are not necessarily the actual part number for the part. The numbers you provided are not valid in the MB parts lookup. I suppose it's possible that I can't see a part if it's not for US use. I've given you all that I know.
Old Jun 25, 2019 | 02:26 PM
actually i asked different people all said to me that this number is not valid but its still confusing though.. anws thank you sir I appreciate your help
