New Billet camshaft for 156/159 video by Tasos
#101
2012 P31 C63 Coupe Trackrat, 2019 GLE63S Coupe Beast
#102
Assuming pricing isn't insane on these, I may jump in and could likely work with Jerry at EC ( I'm in Houston) to get a tune created for them.... this and a few other tweaks that look possible are having me reconsider the ESS charger....given the complex fueling issues of incorpating it along with my E85 setup....
I'd be happy with 550 rwhp NA if it was doable...
E
E
you can run the ess kit and run e40e but you need to also run meth injection to take the strain off the stock fuel system. That way you don’t need to hack up the fuel system. 8psi isn’t that much... the stage 2 weistec does that. But the ess Kit is way more efficient with the gen 3 rotor design. I’d get a custom pulley made and run 10-11 lbs
#105
#106
12 C63BS Magno Alanite Grey, 22 X3M Brooklyn Grey, 08 BMW E93, 22 Ducati Desert Sled, John Deere 3R
#108
2013 W204 C63 AMG P31 Estate wagon
Nope. In fact the Stage 3 C63 that he was putting cams in, one of the 4 stock factory cams he pulled out had blocked oil holes.
Go to 5:50 in the video.
https://youtu.be/-gWrO9WaU50
They were new "Mercedes" camshafts fitted during the rebuild at around 120K.
He said those new camshafts had 40K on them since the rebuild.
He was surprised that the bearing finish and caps had not chewed out with no oil hole
Rebuild was around 120K now on 160+K.
#109
Ok even if they were new, do you think Mercedes updated the manufacturing to now include oil holes that aren’t drilled thru properly? That’s even worse than just having them not correct from the beginning and just not updating them
Cwagon (10-02-2019)
#111
#112
#113
New Vid with link in the comments to gulf performance but still no mention of price anywhere
#114
c63 coupe p31weistec stg3 SOLD,2013 C63 BLACK SERIES.
New Vid with link in the comments to gulf performance but still no mention of price anywhere https://www.youtube.com/watch?v=CY7mukDrDUA
#116
BLKROKT (10-19-2019)
G_Money (10-20-2019)
#123
#125
It’s not that bad...at $5000. 6 is kinda silly... but a custom billet cam for an ls engine is like $800.... the m156 needs 4 so even if you were getting them at ls cost would be $3200... add in the r and d to develope the design on the cam. If it is well developed and they make power that is... otherwise yeah its a waste.
BLKROKT (07-27-2022)
