C63 AMG (W204) 2008 - 2015
Blinker hole troubles
Old Sep 10, 2019 | 03:49 PM
NeverSettle's Avatar
2012 C63 AMG DP
All,
I did a replacement from the yellow indicators to smoked when i got my 63. front left and right sides.
recently, one was becoming loose, and sort of fell out while driving.
I picked up a replacement set from Amazon, but when I went to install the new ones, the plastic trim around the opening (was very thin) bent and broke off. it was about 1/4 of a inch wide, all along the opening. I will post pics when I can, but I wondered if anyone knew of a rubber grommet or trim piece - or should I just silicone them in place?
I have considered getting a replacement front - but i wanted to see if anyone had any suggestions.
I am skilled at fabrication - fiberglass and sculpting - so I may just do something completely custom - but i want to make sure I can get a repair sooner than later.
Old Sep 10, 2019 | 06:51 PM
bhamg's Avatar
C63 AMG
That's the same problem I had with the smoked side markers. They do tend to fall out. I returned the first set but the replacements were just as bad. IIRC I kind of jammed it upwards while pushing the bottom inwards and that seemed to cure it but it's an inherently ill-fitting piece.
Old Sep 11, 2019 | 10:21 AM
2012 C63 AMG DP
It was Precisely when I was doing just that thing when the plastic lip of the hole broke off the car...
