W204 2013 Command & Most Identification
I am looking to carry out an audio upgrade to my W204 C63 (2013) Model. Im looking to use a digital most unit like an Audison BITDMI or Helix SDMI25 however i need to check compatibility on my model.
I am confused whether my vehicle has NTG4.5 or 4.7. i have done alot of reading online but i need to be sure which version it is. I have checked with my Vin number on a vin checker but there is no identification mentioning which one. Is there a way to check in the engineering menu? If so could you please guide me on how to do this. Here is the version information i took from engineering mode:
HU Version: 13.30.00
H/W Information
Device: HU45_ECE_DVD_S_N
H/W P/N: 2049013903
Device Ver: D1 0.1
If anyone can clarify easily, My vehicle uses the grey/white/red colour schemes and looks as follows:
I also need to know what fiber optic the car runs, Is it Most25, Most50 or Most150?
The issue im having is i believe some of the 4.7 cars began using Most50 or Most150 and if that is the case the BITDMI will not be compatible. Unless its very easy to clarify immediately that all W204s used MOST25
The W204 model use MOST25 throughout its models so items like the BITDMI will work.
Previous owner did the upgrades and i paid less for the car because of them.
I have a home theatre set up worth as much as the car so i appreciate good sound.
Phase 1: disconnect HK and use an Audison or Helix DMI device to send an optical connection into my DSP, This would be the cleanest way of doing it to ensure no processor is having to correct factory equalisation
Amplify the original HK front and rear speakers combined with my aftermarket subwoofer (Logic7 subwoofer and surround speakers would be disonnected but left in place)
At this point i will evaluate what the system sounds like with just front components & rear coaxials combined with a subwoofer, If its seriously lacking and i feel the surround speakers really did have an impact at this point i will revert and just fit the HK amp back in and connect everything back as it were factory.
Phase 2: if the output was sufficient then i will switch out he speakers for aftermarket front and rear and drive these with the amp.
