2011 C63 with 59k.
Which pulley kit is best?
Weistek?
Sharduls?
FCP EURO
Weistek and Sharduls are billet.
What is FCP EURO? Is it just OEM parts or better than OEM?
I know it's not billet but it's half the price.
Sharduls seems good but i have seen people having issues with one of the pulleys rubbing on the tensioner with no solution other than shim it out.
Are there any others?
Plan on ordering a set tomorrow just don't know which one.
Any help you all can offer is greatly appreciated.
Weistek?
Sharduls?
FCP EURO
Weistek?
Sharduls?
FCP EURO
Originally Posted by Travis Decker
2011 C63 with 59k.Which pulley kit is best?
Weistek?
Sharduls?
FCP EURO
Pretty sure fcp is oem. The great thing is though if it breaks again it’s lifetime warranty forever. That’s the route I’d go and oem fitment.
Quote:
But if the OEM are known to be garbage and guaranteed to break again why would you use them?Originally Posted by AMGonFire
If they are the exact same garbage parts i won't use them.
I was thinking maybe they were better than oem but just not billet.
They are not garbage they wear out like any part. You got 50k miles out of them so you get another 50k out of new ones. I’d use them cause there is zero benefit to the other ones other then potentially longer lasting however with a lifetime warranty I have life time too for less money. Originally Posted by Travis Decker
But if the OEM are known to be garbage and guaranteed to break again why would you use them?If they are the exact same garbage parts i won't use them.
hachiroku
SPONSOR
close
- Join DateSep 2014
- LocationWorldwide
iTrader Positive Feedback0
iTrader Feedback Score(0)
- Vehicle(s) I drive2007 Mercedes E63 AMG
Liked:818 Times in 580 Posts
go with the bullet pieces if you drive your car hard. my new oem pieces blew in 1 year and maybe 10k miles. took out my thermostat housing along with spraying coolant everywhere.
all it took was one full throttle press, double downshift jerked the engine hard enough to cause the plastic pulley to fail.
Exactly my thoughts. I definitely don't want oem knowing they are ****.Originally Posted by hachiroku
go with the bullet pieces if you drive your car hard. my new oem pieces blew in 1 year and maybe 10k miles. took out my thermostat housing along with spraying coolant everywhere.all it took was one full throttle press, double downshift jerked the engine hard enough to cause the plastic pulley to fail.
But i don't really need billet either. Just figured the Fcp was somewhere in the middle.
Are the three i listed the only ones on the market as a kit?
BLKROKT
close
- Join DateJun 2008
- LocationLos Angeles
- Vehicle(s) I drive2012 P31 C63 Coupe Trackrat, 2019 GLE63S Coupe Beast
Liked:2,867 Times in 1,684 Posts
There are only two upgrade kits, Weistec and UPD. The FCP “kit” is 100% OEM stock.
There was recently a video on YouTube that showed the Weistec pulleys having super cheap bearings. Not sure if Shardul’s are better or not, but that would be the deciding factor for me. If they’re the same, flip a coin and replace the bearings with good ones and they’ll last forever.
Absolutely.Originally Posted by BLKROKT
There are only two upgrade kits, Weistec and UPD. The FCP “kit” is 100% OEM stock.There was recently a video on YouTube that showed the Weistec pulleys having super cheap bearings. Not sure if Shardul’s are better or not, but that would be the deciding factor for me. If they’re the same, flip a coin and replace the bearings with good ones and they’ll last forever.
I am a mechanic by trade and we never use cheap Chinese bearings.
Thanks for the info
ExploreI got the UDP kit and didnt experience any rubbing, In fact, noise level are just like OEM. I did have to change out a bolt style (search thread for the part #). As for bearings, they used a pretty decent type (Nachi bearings).
http://ultimatepd.com/2007-and-up-m1...-g63-cl63.html
G_Money
close
- Join DateJun 2013
- Location'Merica
- Vehicle(s) I drive'04 E55 (Gone but not forgotten), '13 C63 P31 (RIP), another '13 C63 PP
Liked:152 Times in 126 Posts
Ran my last C63 with the full 5 pulley UPD kit for a year. Also had a 5 pulley set on my old E55 for about 5 years. Can't think of a better upgrade for a maximum reliability/durability/longevity build. Whether your OEMs grenaded, or you are putting them in as preventative measure.
Shardul makes a quality product and many, many users have posted here and on the E55 forum attesting to superior craftsmanship of Shardul's products, especially when it comes to his pulley replacement kits!
