Down the ESP Module Fault Rabbit Hole - Xemodex.com Repair Planned
Three weeks ago I had an EBR, ABS, ESP inoperative message on the dash. No power steering, no abs, no ESP, no cruise control. The car drove fine otherwise. It only comes up when the car hits 12 mph. It showed up two times one day and then went away. It never came back after that day so I didn’t run the codes.
A few days ago it started coming up again. Now it happens every time i hit 12 mph after a start. I drove around a couple days like this and then pulled codes.
5001 - ESP internal fault
5944 - ESP internal fault
5938 - check steering angle sensor
7266 - DTR distronic - consequential fault
I don’t get any fault messages on the dash until I hit 12 mph.
I erased all stored codes. Now I only get 5001.
Used my iCarsoft MBII scanner to monitor live data. All sensors seem to be working fine. Steering angle, wheel speed, brake switch, etc. all seem fine.
Unplugged and cleaned the ESP module contacts. No change.
Tried using my spare key. No change.
Reset the steering angle sensor. No change.
Battery is OE and a few months old. Voltage seems fine according to iCarsoft. No voltage related faults.
My conclusion is bad ESP module.
I am planning to send it to Xemodex.com for repair. Any thoughts before I spend $500 sending in the ESP module?
If someone doesn’t have a magic fix, I’ll send it in for repair on Monday and report back at the end of the week.
Oh and OP have you changed your idler pulley bearings yet?? If not, there due!! And go with a billet rebuildable aftermarket set
I drove around watching the live data from the wheel speed sensors and they seem fine. Has to be the ESP module.
Mine was front passenger wheel speed sensor.
And a few years later I got a huge esp error from changing to 16in drag wheels that no other scan tool could reset.
See what your dealer charges to scan the car or go in with the codes to get an oil change and see if they say btw you need this and that to fix your stability problem
