C63 AMG (W204) 2008 - 2015
HMS/Widebody and Unibody
Old Oct 4, 2019 | 08:29 AM
Adi-Benz's Avatar
2010 C300 4MATIC........ 2011 C63 AMG.............. 2015 CLS400 4MATIC.....
Hello guys,
Maybe a dumb question but only way to find out is to ask. So everyone knows when you extend with the fender flares or do a wide body there is cutting of the rear oem quarter panels so that the wheels will have no internal block after the flares are installed. But this means cutting into the Unibody of the car, and isn't that a bad thing? Doesn't this affect the structural rigidity of the car?
Old Oct 4, 2019 | 08:51 AM
Bonesxxx's Avatar
2016 GTs, 2014 C63 AMG and 2014 C350 Sport (wife's car, she thinks it's an AMG - shhhhhh)
I think your assumption is correct. I spent some time as a volunteer firefighter and we received tons of training on extricating people from cars (using cutting tools, cribbing, airbags, jaws of life, etc). The instructor told us that when unibodies replaced vehicle 'frames' the unibodies became the frame. Once the unibody is compromised, car is considered 'totaled'.
Old Oct 4, 2019 | 09:08 AM
BalanBro's Avatar
2012 C63 P31 Sedan
I'm not very familiar with the installation process, but I thought that you are supposed to replace the cut portion with additional sheet metal welded in place.
Old Oct 4, 2019 | 09:12 AM
BalanBro's Avatar
2012 C63 P31 Sedan
Here it is. Check about 2:30 minutes in.
Old Oct 4, 2019 | 09:23 AM
Bonesxxx's Avatar
That sounds correct to me. I'd be surprised if you have to cut into the unibody. The unibody is typically the floor, the A, B (sedan), and C posts and the roof. The entire quarter panel area has no unibody unless you cut into the floor or C post.
Old Oct 4, 2019 | 09:28 AM
Adi-Benz's Avatar
I thought it would be like this image shows?
Old Oct 4, 2019 | 09:47 AM
Adi-Benz's Avatar
Also that video doesn't seem typical - they literally cut the outer shell. Seems like wayyy to much cutting/welding...
Old Oct 4, 2019 | 09:49 AM
Jasonoff's Avatar
Top Answer: 3
2010 C63 AMG
Old Oct 4, 2019 | 09:55 AM
Adi-Benz's Avatar
Danke Jasonoff - so at 1:53, he is spot welding it back shut (as predicted) so that the plates keep together
Old Oct 4, 2019 | 10:14 AM
Bonesxxx's Avatar
^^ that one. Just cutting into the skin.
Old Oct 4, 2019 | 10:28 AM
Jasonoff's Avatar
Top Answer: 3
2010 C63 AMG
It's just a double wall panel. Could probably get away with rivets if you you don't have access to a spot welder.
Adi-Benz's Avatar
Cool. In that case I can carry on my plan when I end up finding the right vehicle (alas the search continues!) Expected product alike:
HMS/Widebody and Unibody-dmxztja.jpg
Old Oct 4, 2019 | 10:37 AM
WreckMyE55's Avatar
Crashed e55
So that’s why you had an sl550 VIN you needed searched 😁
Old Oct 4, 2019 | 12:17 PM
Adi-Benz's Avatar
LOL you got me 😂 almost bought it
Old Oct 4, 2019 | 12:18 PM
WreckMyE55's Avatar
Crashed e55
Why didn’t you? Do you have a c63?
Old Oct 4, 2019 | 12:49 PM
gmaschine's Avatar
W463
Originally Posted by Jasonoff
Thanks for posting!
As long as the 2 sheets of steel are welded back together and sealed there are no issues. This is how the factory does it as well in other parts of the chassis.
Old Oct 4, 2019 | 12:56 PM
Adi-Benz's Avatar
Edit Nah nobody cares
