LSD Weistec or Harrop
for my 507 I went wavetrac and am pleased - it's a bit cheaper then some but seems robust enough and functions smoothly.
E
probably because Chrysler has a history with MB? I remember the Jeep Grand Cherokee has the same platform with old ML? maybe the old stuff are same story
might be your lowest cost option maybe? i believe it may have been mentioned that Drexler produces AMG and Black Series LSD's. Wiestec is a rebranded Wavetrac? then you have Quaife out of the UK as well. Harrop is an Eaton based unit so should perform similarly to the Quaife. depending on application and usage one would be favored over the other. Drexler looks to be a tried and true clutch style LSD which allows for lots of adjustability. Clutch style LSD's tend to be more aggressive in nature, but perform heeps better than any gear/helical type LSD due to the ability for adjustability in terms of lockup, engagement angle, and characteristics.
https://www.m3post.com/forums/showthread.php?t=788992
The Wavetrac works on the same principle but has a pre-load system.
I have used owned both, and also a Drexler.
I have a Wavetrac in my ride.
with any clutch style, you'll want to monitor fluids for metal shavings. metal shavings in your oil is normal as the clutch packs wear on themselves. i personally do not rebuild a clutch style LSD until the function has been drastically affected.
wavetrac is your next best bet to a clutch style since it does have a preload to prevent full 100% open wheel. also, wavetrack and any gear type of that nature will be very durable for all of your high torque needs.
Harrop was not out when I did mine. I would have considered Harrop as an option but not at the mega price they are asking.
Wavetrac = best mod to my car.
Just after I bought my car I was going to get both the diff and trans serviced even the service book said they had been done.
I decided to put in a Wavetrac during the service (also looked at the Quaife) after having one in my old VZ Senator for about 5 years with never a problem.
One thing I really liked about the Wavetrac was that even if one wheel is on a slippery service or even suspended in the air as when negotiating a steep driveway at an angle the other wheel still drives.
I've had mine since 2012, no issues what so ever but I don't think the off the shelf "wavetrac" device generates much friction. In a near zero load scenario (one wheel on smooth ice) it pretty much acts like any other helical lsd.
I believe you can upgrade the plates to a higher friction coefficient though.
I have a steep approach driveway which i had to attack at an angle because of low spoiler, not so much with this car at std height
Any I was sometimes able to get enough traction to move but usually had to pack wood under suspended wheel.
This got me reading about what was available at the time.
After fitting the Wavetrac I never had the problem again.
These bias plates provide a mechanism to tune the response of the differential as a function of applied torque load. The applied torque load manifests itself as an axial load from the differential pinions into the housing. This axial force is then considered a normal force into the bias plate, and as a function of the effective coefficient of friction, provide a resistive torque to the rotational motion of the differential pinions. The resistive torque will add to the resistance of relative rotation of all components within the differential. The resistive force, however, is non-uniform since it is a function of the axial load from the differential pinions. The unbalance of the resistive torque will manifest as non-uniform energy absorption within the differential causing a bias ratio.
US$1200 shipped to Melbourne years ago.
Install locally was 6 hours - Au$792.00. The MB specialist installer I used has since closed.
Whilst you want someone competent at diff work, the complexity of the C63 rear end is where the the benefit of a specialist MB workshop comes in. By all accounts pulling the rear apart is far from your average drop the rear end so familiarity will ensure a quicker job without issues.
The Wavetrac may need a small bit of the housing ground off - as I understand it, anyone with half a brain and a grinder could deal with that aspect.
You need to find yourself a good independent MB specialist service agent for ongoing servicing. They would be a good place to start in getting a fitting quote.
