C63 AMG (W204) 2008 - 2015
507 Edition smoking under the hood..
Old Nov 24, 2019 | 12:43 PM
ecohen2's Avatar
Hey Folks,
I have a 2014 507 edition that now lives in a very dry, temperature controlled garage in Colorado. Unfortunately it only gets driven about 800 miles a year. At the end of last month I drove it quite a bit, lots of good highway driving and mountain roads. Yesterday I started it up after about a month of sitting and drove it to a local gas station. When I arrived there was a considerable of oil smoke coming out from under the front hood on the driver side. My guess is that I have a bad valve cover gasket or something.
Does anyone have any thoughts?
Thanks,
Ed
Old Nov 24, 2019 | 12:52 PM
Texas E63's Avatar
Built 2008 G55 & one big 80 Series LandCruiser !
you need to get more miles on it, or at least get it to running temp every month...... seals don't like sitting.... I'm thinking you're correct on the gasket.... I bought a super low mile RS6 years ago that was seldom driven and came from a southern state, and had to R & R most everything that was a gasket to get it to run correctly or not drip oil....
Old Nov 24, 2019 | 12:55 PM
roadkillrob's Avatar
Top Answer: 1
12 C63BS Magno Alanite Grey, 25 X5 Msport, 08 BMW E93, Ducati Hyper 698
Probably a valve cover seal, drivers side one seems to be the one that goes first for some reason, pop out the airbox on that side and it is easy to get a good look, usually leaks in the lower rear corner.
Old Nov 27, 2019 | 09:48 AM
latinskllz's Avatar
'21 GLE53, ‘11 E63, '13 M3
Hope you figure out what the issue is. LMK if you’d ever like to meet up and go for a cruise with others. I too have a ‘14 507
