C63 AMG (W204) 2008 - 2015
Liqui Moly recommended against running Molygen
Old Apr 27, 2021 | 12:53 PM
Kriston's Avatar
C63 AMG
Been Running Hi-Tec + Ceratec Dose every other Oil Change for the last few years and really dont have any lifter noise etc. Very happy with it.
I use Molygen in my X1 and its been great so far.
Old Apr 27, 2021 | 02:09 PM
Asian's Avatar
11' c63 p31
Had an exchange with LM rep regarding liechtlauf vs molygen, my main concern was approval vs recommendation.
“The main reason for using an approved oil is to make sure the factory warranty will not be affected but it can be an advantage to use it even later in the life of the vehicle.
Molygen New Generation is not approved (as you pointed out) due to it's high tech and unique additive package that reduces friction inside an engine which was mainly designed to accommodate modified/tuned, track and/or race vehicles. Even so, it will provide proper protection and fulfill all of the specifications necessary for an oil to have the MB229.5 specifications and since we guarantee this to be true, we can safely recommend it for use in your (and other) M156 engine.
The benefits are lower friction which results in lower oil temperatures, less wear, improved efficiency and usually a more quiet engine.
If you feel the need to stay with an approved oil use Leichtlauf High Tech 5W40 which in itslef is a very protective and high quality oil that can be used in day-to-day driving and/or at the race track.”
guess I’m just freaking out over nothing.
Old Apr 27, 2021 | 02:47 PM
swedepat's Avatar
2011 C63 AMG, 589hp
I use Fuchs(Silkolene) Titan GT1 5w40 ,specs :MB 226.5, MB 229.31
As it is classed to run in dieselengines also, it got more 'cleaning' additives which is good for cleaning the tappet hydraulics.
I also pour in Red Line Additive i posted above to gain ZDDP levels, this to preserve the camshafts.
I got no lifter noice what so ever., nothing, nada, and engine has run slightly above 120000km.(~75000miles)
And bonus, oils classified for diesels are often able to withstand higher cylinderpressures, (forces on the bearings)
Higher filmstrength.
Old Jun 4, 2021 | 01:06 PM
1SickGLC's Avatar
2018 MB GLC 43 AMG
Could I assume using Molygen or High-Tech in a 5w40 or 0w40 application would in fact be ok to use on my 2018 GLC 43 AMG? I'm almost to my change interval and wanted to use the proper oil. Mobile1 is approved, but know others are great options as well. I have read through the above, but noticed most, if not all were 63 or 63s applications.
Old Jun 4, 2021 | 02:12 PM
BLKROKT's Avatar
2012 P31 C63 Coupe Trackrat, 2019 GLE63S Coupe Beast
No, you can’t assume anything. Look in your owners manual or ask the GLC450 forum what the correct oil is.
Old Jun 4, 2021 | 03:21 PM
doncmleon's Avatar
2012 C63
I started using LM earlier this year and absolutely LOVE it. Even the shop who did the oil change IMMEDIATELY commented on how much quieter the car ran. It was very noticeable.
I'll be using MolyGen, along with their Engine Flush now. I bought everything from FCO Euro and they treated me well.
Old Jun 5, 2021 | 11:57 PM
  #32
Kriston's Avatar
C63 AMG
Had lunch with a LM rep before the pandemic and he advised to stick with the high tech + ceratec for the m156. The ceratec I can stand by as a long term user, it actually works wonders for lifter noise.
molygen has mos2 as the additive. Do not use molygen + ceratec. It’s a waste. I never ran molygen in the m156, the results with the high tech * ceratec is good enough for me
Old Jun 6, 2021 | 07:51 AM
  #33
Jasonoff's Avatar
Top Answer: 3
2010 C63 AMG
The LM High Tech 5W40 thins out at operating temp though (Viscosity at 100 °C 12,9 mm²/s) which makes me wonder how it is at 130 °C
Old Jul 7, 2021 | 04:24 PM
  #34
ahering's Avatar
2005 E500
Originally Posted by skratch77
I'm on my second oil change with just molygen and no additives and I'm sticking to it. Maybe talk to one of there engineers because molygen is supposed to be there best oil yet.
Just wondering if you are still using Molygen, I just replaced oil on my 2005 E500 and used Molygen 10W30.... do you still like it?
Old May 24, 2022 | 10:00 PM
  #35
skullbox15's Avatar
2014 C63
Necroposting here... I had a Indy shop put in some fresh Molygen since they were doing some other work on the car. The guy at the shop said the dye added to this oil makes it acidic which eats the engine parts over time. Not sure I believe that but food for thought.
Old May 25, 2022 | 03:36 PM
  #36
BLKROKT's Avatar
So you had them put this oil in anyway after both he and the actual manufacturer said not to run it in our engines?
Old Mar 26, 2023 | 10:52 AM
  #37
Fermin Grajales's Avatar
2002 Mercedes Benz S430
MOLYGEN!
Molygen is PHENOMENAL. I have been running it in my 2011 W212 E350 4Matic Luxury that gets driven like it's on the Autobahn regularly. Used it for 6.oil changes so far. PRO LINE ENGINE FLUSH and idle for 15 20 minutes with slight reving in between to clean the engine well. PRO LINE GASOLINE SYSTEM CLEANER in the tank after. Car drives like a race car. Smooth as butter sitting on a window sill catching sun rays. Revs great at 6200 RPM's in 2nd gear. Maintains its viscosity better than any other oil I have ever used on cars that were being driven like movie set vehicles from the Mad Max Thunderdome movie. I love this oil. LIQUI MOLY for my W212 only.
Old Mar 26, 2023 | 06:51 PM
  #38
roadkillrob's Avatar
Top Answer: 1
12 C63BS Magno Alanite Grey, 25 X5 Msport, 08 BMW E93, Ducati Hyper 698
2 things:
1. How much where you paid for this post?
2. Since I created this thread long ago, Molygen 5W40 has been certified as MB 229.5 and is fine to run in the M156.
Old Mar 27, 2023 | 10:49 AM
  #39
swedepat's Avatar
2011 C63 AMG, 589hp
*lol*, working on a novel maybe?
Old Mar 27, 2023 | 01:53 PM
  #40
hachiroku's Avatar
SPONSOR
2007 Mercedes E63 AMG
seems like that, "related topics" scroll function caught another member.
__________________
-BARRY
​​​Follow us on instagram @eightysixtuned
https://www.eightysixtuned.com
Old Mar 28, 2023 | 08:46 AM
  #41
W205C43PFL's Avatar
I wish it was default as off but it can be turned off which I think you are aware, not sure if others do though.
Old May 11, 2023 | 12:15 AM
  #42
Audi Junkie's Avatar
E Coupe C207, ML W166, ML W164, Sprinter 1500/144, W111 SB220 Fintail(s), A5 chassis Beetle 5+5
Old May 18, 2023 | 09:59 PM
  #43
amg-avantgarde's Avatar
W212 E300 AMG Sport
Couldn't agree more. That's exactly what I've been running on my 350 for 10 years. Hasn't put a foot wrong. To add, I do combine it with Liqui Moly DI Jectron to clean my injectors.
Old May 20, 2023 | 01:13 PM
  #44
How does someone obtain comparative data about an oil if they have only run one kind, or if they have never done any lab work on it?
I could run Quaker State 10w-40, without a "problem", then insist it's the best, based only on a sample of one. Run your oil, do a lab report, then run Rotella and do the same. Then let me know how your Euro oil is working out, at double the cost.
Old May 4, 2024 | 04:50 PM
  #45
kafklatsch's Avatar
All Cars Lost To Hurricane Isaac (W124 E420 revived - added 88 Allante 14 S550, 17 S63
I'm on the late show here.... with Johnnie Carson no less
It is interesting that only the 10w-40 molygen is approved for MB 229.5
can someone speculate on why not then the 10w-30 also?
is it actually approved and not "still" just recommended?.....not clear on my web search
I've used the molygen 10w-40 weight for 4 oil changes (2cars) and it is 100% noticeable improvement... versus a very good AMsoil... and 3rd place but still good mobile one..
Originally Posted by roadkillrob
2 things:
Old May 4, 2024 | 10:29 PM
  #46
roadtalontsi's Avatar
10 C six trizzle
Interested in how much oil consumption you guys see. Strange cars that never consume oil run liqui moly and burn 1-2qts by 5-6000 miles. Im no oil engineer but that doesn't seem normal. Then you switch them back and they dont burn oil. Not sure why but that's been my experience over multiple vehicles and engines. Not a fan. Lots of hype and marketing. I can get liqui moly for much less than just about any other synthetic oil too.
Old May 4, 2024 | 11:13 PM
  #47
kafklatsch's Avatar
My oil consumption was/is
1/2 to 3/4 quart per 5k on my m278 with Mobile 1
1/2 with Amsoil
1/4 with molygen (current)... was really blown away by that... I started checking very frequently because it was so little
My S63 is babied and garaged... about 1/2 quart per 5k with Mobile 1... i drive it so little that i havent changed the oil manufacturer
Also did my came adjusters and when the engine was open it looked like new, absolutely zero dark residue or gunk... only clear oily surfaces everywhere... frigging fantastic...that was Mobile one and amsoil... only one use (my first) of molygen at that point..so I won't contribute that condition to the molygen, but who knows..
Old May 4, 2024 | 11:53 PM
  #48
MB2timer's Avatar
Veteran: Army
Veteran: Navy
SL63
I am glad that one of our members (kafklatsch) mentioned amsoil. Nothing against it, I have heard strong support for it, and really no bad mouthing of the product that I have ever seen. So it’s probably very good. But is it the best? It seems like after seeing some of the measurements and data already mentioned in the thread, it should be more objective, than subjective to say which is the best.
It looks to me like the tungsten based product has a lot of advantages over the molybdenum based additives.
I just like the idea of the fluid inside the engine protecting and preserving the engine, instead of the engine wearing itself out for lack of a sacrificial lamb so to speak.
Old May 5, 2024 | 02:36 AM
  #49
No, it is not approved nor will it be since it's extra additives create extra deposits, which are strictly limited by Mercedes.
https://www.infineuminsight.com/medi...-pages-002.pdf
https://pim.liqui-moly.de/pdf/en_GB/liqui/35/P001759
What are your goals running this oil? Have you done any lab work to ascertain problematic wear rates, or...?
Old May 5, 2024 | 02:38 AM
  #50
I would run Mobil 1 High Miles 10w-40 unless it's cold, then add some 5w-30 to it.
