C63 AMG (W204) 2008 - 2015
63 cut
Old Jan 15, 2020 | 04:46 AM
63 Molar's Avatar
C63 AMG
Unhappy 63 cut
Coasting in neutral giving the car some revs to deplete the E85, so i can swap back to 98 pump gas and the car CUTS out. Thats it. Over and out.
At present cannot start the car. It tries to crank, but nothing.
Replaced the battery with no luck.
On key ignition - all lights, twin fuel pumps stay on feeding fuel, turn the ignition to ON and tries to crank, lights on dash dim etc... No CEL or warnings ....
Alternator unlikely as the battery is new with over 1000 CCA,
Starter motor - possibly..., however engine cut out when car was on and in motion.. Perhaps the electrical to starter is fried .....
Cam shaft, Crank shaft position sensor ? maybe ....
faulty fuel pumps ?
ignition coils ...
plugs ....
Any suggestions would be valuable.
Thanks guys.
Old Jan 15, 2020 | 08:50 AM
skullbox15's Avatar
2014 C63
Sounds like crankshaft positions sensor, but I don't think that's as common as it was on the W203 cars. Looks like your car is heavily modified. When was the last time you changed anything? Days, weeks, months?
Old Jan 15, 2020 | 11:57 AM
curt.r's Avatar
2013 P31 C63 Sedan
faulty fuel pumps ?
ignition coils ...
plugs ....
Thanks guys.
Did it throw any codes? I’d guess either a camshaft position sensor or crankshaft position sensor, but if it was either of those the car would’ve thrown a code. If the CEL isn’t on, it's most likely a fuel issue. This might sound silly, but maybe your fuel gauge might be off and you ran out of fuel?
EDIT: Or since E85 is hygroscopic, it's possible that the E at the bottom of your tank had a high moisture content. I'd keep it simple for now. Drain the tank, get the old E out of the fuel lines, put a little bit of new E in the tank (since your car is tuned for it), and see if she starts up.
Old Jan 15, 2020 | 04:47 PM
hachiroku's Avatar
SPONSOR
2007 Mercedes E63 AMG
if you're not on an E85 specific tune you'll need to reset the ECU using a device which will reset your fuel trims and adaptations for the engine.
__________________
-BARRY
​​​Follow us on instagram @eightysixtuned
https://www.eightysixtuned.com
Old Jan 16, 2020 | 05:11 AM
63 Molar's Avatar
C63 AMG
Hey there, I am on a custom E85 tune man.
Old Jan 16, 2020 | 05:12 AM
63 Molar's Avatar
C63 AMG
No codes thrown.
Its at the dealer as i type. Will let all know the outcome.
Old Jan 16, 2020 | 05:14 AM
63 Molar's Avatar
C63 AMG
Perhaps removing the plugs and trying to turn the crank by hand ?
check the ignition coils
and try start up ...
Old Jan 16, 2020 | 08:46 AM
hachiroku's Avatar
SPONSOR
if you're on a E85 tune you may need to ask your tuner for a new map. E85 is 108-109 octane and it wouldn't be wise to switch gas without updating your engine computer mapping. even at the tune of 105 octane, is still far from 98 RON pump gas which would equate to 94 octane.
the Mercedes Bosch ECU has many fail safes built in to cut out or go into limp mode if it senses something is wrong to protect your engine.
Old Jan 16, 2020 | 09:10 AM
Bonesxxx's Avatar
2016 GTs, 2014 C63 AMG and 2014 C350 Sport (wife's car, she thinks it's an AMG - shhhhhh)
"Twin fuel pumps - 1070 cc injectors - E85, 98 pump tune, HKS cold plugs"
From his OP it looks like he has two tunes. That's why he was trying to run out the E85.
Old Jan 16, 2020 | 10:04 AM
skratch77's Avatar
2005 E55
When I ran 630cc injectors and e85 my car shut off in park in my driveway all by it self.
It was my last try to get it to run right and was the reason I took the kit off.
Old Jan 16, 2020 | 12:47 PM
hachiroku's Avatar
SPONSOR
630cc's are big...i have 596cc's and i'd see bursts of -30 fuel trims and steady state register -23 to -27 fuel trims. this all is on a 91 octane flash tune.
what i can tell you about the computer and fueling after 3 months of fine tuning HPTuners is that, if the computer see's too rich or too lean and deems it uncorrectable, it will go into a hard limp mode and you will not be able to drive faster than 2mph.
__________________
-BARRY
Old Jan 16, 2020 | 12:55 PM
skratch77's Avatar
2005 E55
I think you have 630s as a few places list them as different numbers.
flex fuel kits are good on stock injectors but suck with bigger injectors. Heck you might be able to run e85 without a flex kit on 600 cc injectors and let the factory ECU do its thing
Old Jan 24, 2020 | 04:48 AM
63 Molar's Avatar
C63 AMG
So, my pain continues. Removed plugs, car will not turnover.
its seems to be seized.
We have not removed the serpentine belt as of yet to see if we can turn the crank,
Car getting shipped back to Sydney for assessment and repairs.
I am praying the bottom end is sound, rods, pistons, crank etc....
Will keep all informed.
IF ANYONE HAS SUFFERED SIMILAR PROBLEMS PLEASE CONTRIBUTE TO THE POST
Matthew
Old Jan 24, 2020 | 04:57 AM
63 Molar's Avatar
C63 AMG
She was an absolute ripper. I pray for a resolution. Always cared for, somewhat of a garage queen to be honest.
Old Jan 24, 2020 | 04:59 AM
63 Molar's Avatar
C63 AMG
Old Jan 24, 2020 | 05:02 AM
63 Molar's Avatar
C63 AMG
Yes Sir
Old Jan 24, 2020 | 05:21 AM
63 Molar's Avatar
C63 AMG
MONSTER
