C63 AMG (W204) 2008 - 2015
Stage 3 Weistec smaller pulley
Old 01-18-2020, 07:01 AM
NAPARM's Avatar
C63 AMG
I currently run the 67mm pulley.
The next size down everyone runs seems to be a 60mm pulley but on Weistec’s site I can only see a 62mm pulley. Is that all they make now?
Cheers
Old 01-18-2020, 03:58 PM
mr747's Avatar
c63
Cheers
looks like something they offer with the new Gen blowers it used to be 60mm
Old 01-18-2020, 04:53 PM
NAPARM's Avatar
C63 AMG
https://www.weistec.com/62mm-grooved-idler-8-rib.html
Is this all I need mate? It says bearings and snap ring sold seperate so not sure if I need to get those too.
Cheers.
Old 01-18-2020, 05:00 PM
mr747's Avatar
c63
That's all you need and heavy duty green belt
Old 01-18-2020, 05:03 PM
NAPARM's Avatar
C63 AMG
Sweet already have the green belt.
Old 02-17-2020, 12:05 PM
ChiCho55AMG's Avatar
W209 CLK55 AMG Kompressor, ATV BRP 800 CAN-AM
Can anyone confirm if K081124HD is the correct belt number for C63 Weistec
Old 02-17-2020, 02:06 PM
chawkins2001's Avatar
2006 E55 AMG
I run a 56mm pulley on my newer gen blower, but this is on a m113K motor?
Old 02-17-2020, 03:37 PM
mr747's Avatar
c63
Have also run 57mm on newer GEN but seems 60mm is sweet spot and keeps IATS in check anything smaller just over spins blower
Old 02-17-2020, 06:43 PM
Phil1305's Avatar
C63
can you run 60mm on stock p31 motor, or does it have to be built?
Old 02-17-2020, 06:46 PM
mr747's Avatar
c63
stock motor takes it easy just make sure you have enough octane IE racefuel
i was running it on cast pistons you have forged piston No issues there
Phil1305 (02-17-2020)
Old 02-17-2020, 06:55 PM
NAPARM's Avatar
C63 AMG
Mine’s stock mate so I hope so 😂
mr747 (02-17-2020)
Old 02-18-2020, 06:29 AM
Phil1305's Avatar
C63
Cheers.
pretty sure the 62mm is just an idle pulley not the 60mm blower pulley.
Old 02-18-2020, 11:34 AM
2006 E55 AMG
How much boost are you seeing on the 60mm bro?
Old 02-18-2020, 01:10 PM
NAPARM's Avatar
C63 AMG
Correct mate. Not sure why the 60mm pulley isn’t on their website.
Old 02-18-2020, 04:21 PM
mr747's Avatar
c63
13.8 to 14psi on 60mm with stock heads and 14.8 to 15.2 on 57mm stock heads
Ported heads i have seen customers cars on 60mm make 10 psi
Phil1305 (02-18-2020)
Old 02-18-2020, 05:00 PM
deadlyvt's Avatar
2010 C63 AMG
damn porting the heads made that big of a difference? Bigger valves as well or standard?
Old 02-18-2020, 05:55 PM
mr747's Avatar
c63
standard valves bud yeah makes massive difference
Old 02-18-2020, 05:57 PM
Phil1305's Avatar
C63
might have to pull mine for porting.......
Old 02-18-2020, 06:12 PM
mr747's Avatar
c63
Just put it on Nitrous
Old 02-18-2020, 06:37 PM
Phil1305's Avatar
C63
lol, I have a power adder on the way😉
why else would I be in a 60mm pulley thread!
Old 02-18-2020, 06:57 PM
mr747's Avatar
c63
Love it mate go hard
Old 02-18-2020, 06:59 PM
Phil1305's Avatar
C63
your car is one of the first that made me fall in love with weistec c63. Although I do want to put a 150 shot on just to experiment and have fun, but maybe I'll throw a 100 on top of the blower.
Old 02-18-2020, 07:10 PM
mr747's Avatar
c63
I didnt get a chance to spray my car with the blower but i wish i did maybe on the new setup
Keep us posted on your new mods
Old 03-16-2020, 09:43 PM
AbsoluteGr8est's Avatar
11 C63 AMG
Good info guys!
Can someone help me with fuel system?
1. I have am installing a stage 3 (67mm) and not sure what I need to upgrade on the fuel system. Can someone help me out here?
2. I will upgrade to 60mm at some point. Whats the next fuel upgrade?
Thanks in advance!
Old 03-17-2020, 12:22 AM
Phil1305's Avatar
C63
Originally Posted by AbsoluteGr8est
Good info guys!
Thanks in advance!
that info is not commonly given out too detailed. Mr747 gave me some info.
pump gas you should be fine on the stock system.
I was told you'll need 3 pumps on e85 or well you'll max out 2 450's.
I personally plan to run 2 e5lm pumps but it's not plug and play and will be upgrading the whole fuel system.
AbsoluteGr8est (03-17-2020)
Quick Reply: Stage 3 Weistec smaller pulley
