Weistec tune question
Has anyone used the cypher handheld tuner? Wondering how easy this handheld is to use.
I've had the eurocharged V7 tune for about a year, ready to try something new, see if I can maintain the bump in power but improve driveability.
Originally Posted by palolo6.2
I live in CA and will need a stock tune to pass smog. So I'm looking for the best tune I can upload or flash back to stock myself.
I have not smogged the car yet, but my understanding is there are few if any tunes that are CARB compliant. So I want the ability to flash back to stock easily.
If you're on stock exhaust and manifold, then you wouldn't need your canned tune to turn off those monitors would you? That doesn't seem to make sense assuming stock exhaust that is. My car is stock, has a tune, and just passed SMOG FWIW.
When I asked for a retune after I deleted my primary cats so I wouldn’t get a check engine light, Eurocharged stated that Cat deletes were already apart of the v7 tune and no retune was needed.
Crya (01-21-2020)
Loss of secondary cats will not trigger a CEL, however, you can fail visual inspection.
Source: I am a smog technician
Thanks for the info. Weistec also confirmed it's CARB compliant. I still like the option of flashing back and forth though. I guess no one has used the Cypher Handheld?
cypher handheld is the same device as Eurocharged. They are mygenius. Weistec’s Tune was much smoother than EC for me. All around it felt better as well. No jerky transmission.
