C63 AMG (W204) 2008 - 2015
Has this ever happened to your AMG?
Old Feb 3, 2020 | 08:00 PM
Charbel63's Avatar
2012 c63 base coupe
Hey guys.
I own a 2012 C63 base Coupe. 105k miles on it. The other day I was going down the free way when suddenly:
“Inoperative, See operators Manual”
I pulled to the shoulder, the car was idling like crazy, RPMs would dance between 1k-2k, wouldn’t accelerate passed 10 miles an hour, then would limp heavy, power breaking was gone, steering I was still able to do, but that’s about it.
Had it towed home, a friend of mine checked the codes and it read “P2111” and it seems it’s the Throttle Body Actuator that is “Stuck Open”
I was able to turn it on after this happened, it would idyl roughly for about a minute and shut off, till eventually now if I try to turn it on, it fires up then immediately shuts back off.
So my question is, Has anyone you ever experienced this, or had it happen to them? If so, was it the throttle bodies or a wiring harness malfunction? And could it be other things as well?
Also, could it be something else was damaged given it would at least turn on roughly before, as opposed to now just firing up and not a second later it shuts back down?
Any feedback is highly highly appreciated, it’s been a depressing few days without my baby to say the least. You guys know how it is.
Old Feb 4, 2020 | 08:56 AM
manuelsm's Avatar
C63 amg
mine had those symptoms and it was one bad throttle body, you have to know which one is it.
Old Feb 4, 2020 | 01:30 PM
Charbel63's Avatar
2012 c63 base coupe
Thank you so much 🙏 I was hoping I would hear this, gonna take her apart and troubleshoot the two throttle bodies, could be one could be both, could be a wiring malfunction. Will update this forum!
cheers
Old Feb 4, 2020 | 01:59 PM
bbirdwell's Avatar
Veteran: Army
'99 and '05 E55 AMG
FWIW, a similar situation on my M113K turned out to be debris (the large rubber o-ring seal between the throttle body and air intake tube) jammed under the throttle plate. Same symptoms, similar code, similar ESP message on the instrument cluster. After towing the car home, it literally took me < 5 minutes to remedy. It was my own fault as I'd failed to ensure the gasket was seated properly on the throttle body when I removed/installed the air filters the weekend before.
Old Feb 5, 2020 | 12:25 AM
Charbel63's Avatar
2012 c63 base coupe
It’s worth a lot. Thank you for sharing, I will be taking her apart this weekend. I’ll post an update ✌️
Old Feb 14, 2020 | 12:52 AM
Charbel63's Avatar
2012 c63 base coupe
Fixed
One of the shrouds snapped and went inside the throttle body while it was opened. Removed both shrouds completely and car is running great
Old Feb 14, 2020 | 10:03 AM
BLKROKT's Avatar
2012 P31 C63 Coupe Trackrat, 2019 GLE63S Coupe Beast
Wow, that's crazy. Never seen that one before. Good thing it didn't get sucked into the engine. Go buy a lottery ticket.
Old Feb 14, 2020 | 10:05 AM
CyanideRide's Avatar
S/C C63
WHAT IN THE WHAT.
Old Feb 14, 2020 | 10:36 AM
skratch77's Avatar
2005 E55
I have some good news for you ! Your car is not a 2012 base c63 coupe. Those are 82mm throttle bodies.
Old Feb 14, 2020 | 10:38 AM
manuelsm's Avatar
C63 amg
aren't those renntech throttles?
Old Feb 14, 2020 | 12:17 PM
hachiroku's Avatar
SPONSOR
2007 Mercedes E63 AMG
i concur...those throttles, 3d printed throttle body horns, aluminum shielding, and rear plate looks mighty nicer than stock.
__________________
-BARRY
​​​Follow us on instagram @eightysixtuned
https://www.eightysixtuned.com
Old Feb 14, 2020 | 11:38 PM
Adi-Benz's Avatar
2010 C300 4MATIC........ 2011 C63 AMG.............. 2015 CLS400 4MATIC.....
Well "looking nice" almost nuked the engine
But hey 82mm tho
Old Feb 15, 2020 | 03:51 PM
hachiroku's Avatar
SPONSOR
and people said my steel mesh reinforced epoxy airbox air horns would crumble. . guess 3D printing is clearly not better. it would seam that the 3D print leaves hundreds of seam lines that paired with harmonics and vibration can snap along those lines.
__________________
-BARRY
