C63 AMG (W204) 2008 - 2015
C63 AMG Oil Cooler solution! Reasonable 44O option!
Rating: Thread Rating: 3 votes, 5.00 average.
Old 01-27-2023, 04:32 PM
  #326
SRG_C63's Avatar
C63 AMG PP+ 2010
Another small update:
From 03/01 there will be significant delays. The company where I have the lower and upper air duct manufactured will close.
I have to find another company and don't expect to keep the same price. We had close contacts with the company.
However, within the next 2 weeks, air ducts can still be manufactured.
I was able to renegotiate the prices for the coolers though and it will stay the same for now.
No idea how long, is a crazy time.
Old 03-06-2023, 08:27 AM
  #327
unagidon's Avatar
2013 C63
Install Went Great
Sven,
Your cooling kit was installed this weekend.
Went great. No issues. Temp gauge now indicates several degrees cooler compared to before on same runs. Also oil temp drops faster when going from in-town traffic to highway.
I had a local guy powder coat the duct work with a satin black.
You do nice work. Kit is perfect.
Other work this Saturday was R&R plugs and injectors and PCV and serpentine belt and 4 coolant hoses, oil change, install Weistec catch can, install Weistec idler pulley kit, change coolant.
The guy who did the work did a great job. 2013 C63 P31 with 70K miles.
Thank you,
John
The following 2 users liked this post by unagidon:
Cwagon (03-06-2023), SRG_C63 (03-07-2023)
Old 03-15-2023, 02:52 PM
  #328
unagidon's Avatar
2013 C63
Another Photo
Another Photo.
Almost invisible.
INS1GNIA (03-15-2023), SRG_C63 (03-22-2023)
Old 03-16-2023, 03:54 AM
  #329
NZ-Merc's Avatar
W204 C200, BMW E30 M3, 1980Gt Mini, Toyota Corona, KTM 200 EXC.
Looks very good well done.
I have a question on oil cooling, has anyone experimented with adding a power supply to the original oil cooler fan that is controlled by an externally mounted thermostat
that will turn on the oil cooler fan at say 95 deg cel to see if that would help lower oil temp ?
Old 03-16-2023, 05:16 AM
  #330
Cwagon's Avatar
2013 W204 C63 AMG P31 Estate wagon
When I fitted the larger oil cooler, I removed my auxilliary oil cooler fan (like on the factory 440 option) because you can see how it restricts airflow.
NZ-Merc (03-23-2023)
Old 03-16-2023, 10:27 PM
  #331
Diabolis's Avatar
W204 C63 Coupe, W166 ML350 BlueTEC, 928GT, C5 Z06 & IS300 race cars, EQE 4Matic+ on order
^ What @Cwagon wrote. It is the effective surface area of the oil cooler(s) that is the limiting factor, and the fan blocks 40% of the one in the wheel well. The fan helps if you have overheated the oil and then get stuck sitting stationary in rush hour traffic, but driving at 50 km/h pushes five times as much air through that cooler as the fan can suck, and it still isn't enough. Sucking in air at 10 km/h through the same (small) opening won't do anything when pushing air in at 50 km/h - or for that matter, 150 km/h - which is my average speed around CTMP in the C63 - isn't enough.
The 44O kit completely opens up that area - as in the AMG engineers decided to completely scrap the fan - and replaces that cooler (which is a dual core unit) with a triple core in addition to installing a larger one at the front similar to Sven's setup.
Old 03-22-2023, 12:30 PM
  #332
SRG_C63's Avatar
C63 AMG PP+ 2010
To all people who are currently enquiring:
Currently there are waiting times of about 4-8 weeks due to lack of material and holidays. Plan for this if you are considering taking a cooler!
Old 05-22-2023, 05:11 PM
  #333
SRG_C63's Avatar
C63 AMG PP+ 2010
Hello together,
Since I get more and more requests:
Yes, I still sell the cooler. Just send me an E-Mail.
However, there are a few delivery problems again.
With current order, a shipment will take place at the end of July.
Greetings
Old 05-23-2023, 06:39 AM
  #334
DRBC43AMG's Avatar
Location: Land of mountains, cheese, chocolate and watches
12' W204 C63 AMG coupe "T-Rex", 12' W451 Smart Fortwo Pulse (99' W202 C43 AMG sold)
Has anybody measured the extra oil which needs to be put into the engine after an oil and filter change, including the enlarged oil cooler?
My coupe was in for a 'B'service recently and after driving a couple of days later, the warning "low oil level, check at next petrol fill up" lit up. I assume the dealer put back the prescribed quantity of oil without taking into account the quantity needed for the enlarger cooler. I suspect the level was checked before the thermostat had opened, otherwise they would most likely have noticed something was wrong. Furthermore, I topped up shortly after with 1lt of oil to get the correct level on the dip stick
Old 05-23-2023, 06:40 AM
  #335
SRG_C63's Avatar
C63 AMG PP+ 2010
As you already mentioned: The larger oil cooler need 1L more oil.
Old 05-23-2023, 10:48 AM
  #336
DRBC43AMG's Avatar
Thanks Sven for the confirmation. Now I can confirm and ask the dealer to put a note in my service file for next time.
Old 06-05-2023, 02:26 PM
  #337
Adi-Benz's Avatar
2010 C300 4MATIC........ 2011 C63 AMG.............. 2015 CLS400 4MATIC.....
Emailed
Old 06-20-2023, 05:13 PM
  #338
Arnav's Avatar
2013 Mercedes-Benz C63 AMG (C204)
Just ordered mine! Fingers crossed it gets here before trackday season starts for me in August!
Old 06-22-2023, 12:35 AM
  #339
Mitch604's Avatar
2012 c63
@SRG_C63 I sent an email a bit ago and didn’t get a reply. Could you please get back to me at fleischer.mitchell@gmail.com
thaanks
Old 06-22-2023, 01:01 AM
  #340
SRG_C63's Avatar
C63 AMG PP+ 2010
Originally Posted by Mitch604
@SRG_C63 I sent an email a bit ago and didn’t get a reply. Could you please get back to me at xxx
thaanks
Hey, I replied on 05 / May. Check your spam folder. I'll send you the email again.
Better edit your post to keep your mail anonymous.
Old 07-06-2023, 07:16 AM
  #341
G_Money's Avatar
'04 E55 (Gone but not forgotten), '13 C63 P31 (RIP), another '13 C63 PP
Email sent.
Old 07-25-2023, 12:04 AM
  #342
PP-PRO_C63's Avatar
W204 C63
Email sent.
Old 07-26-2023, 04:16 AM
  #343
DRBC43AMG's Avatar
Originally Posted by PP-PRO_C63
电子邮件已发送。
Sven, I hope you are fluent in oriental languages
The following 2 users liked this post by DRBC43AMG:
PP-PRO_C63 (07-26-2023), SRG_C63 (07-26-2023)
Old 08-26-2023, 10:20 AM
  #344
Arnav's Avatar
Another happy customer! Had a couple back to back weekends on a relatively slow track (top speed <90) and didn't hit limp mode once. Worth every penny!
The following 4 users liked this post by Arnav:
Cwagon (08-26-2023), DRBC43AMG (08-27-2023), SRG_C63 (08-26-2023), Thrilla (09-28-2023)
Old 09-22-2023, 10:28 AM
  #345
SRG_C63's Avatar
C63 AMG PP+ 2010
Any new reviews?
Old 09-23-2023, 01:35 AM
  #346
NZ-Merc's Avatar
I am interested in what the heat temps are just with normal driving like on the motorway say 60 miles an hour.
Has it changed engine oil, water and transmission temp.
The reason I ask I have a 1987 M3 and the oil temp slowly rises to about 90 deg c after about 15 km drive on the motorway on a warm day, nothing like the M156 which has a cranking heat and takes no time at all to reach 100+ deg c.
For an idea can a fitting be made that goes between the oil cooler and oil cooler inlet hose that will allow water to be pumped through the fitting over to a water radiator to disperse some heat?
Old 09-23-2023, 05:39 AM
  #347
DRBC43AMG's Avatar
When driving at a steady 130km/h on the motorway with summer temperatures +/- 30°c, oil temp is always sitting between 105°-107°c with water temp at a 90-93°c.
Cwagon (09-24-2023), NZ-Merc (09-23-2023)
Old 09-24-2023, 05:11 AM
  #348
Cwagon's Avatar
Virtually the same as I get when travelling at similar speed.
Old 09-28-2023, 10:31 PM
  #349
Zinny84's Avatar
c63 AMG
Any new reviews?
PM sent via Instagram @SRG_C63
Old 10-30-2023, 08:18 PM
  #350
ruxa222's Avatar
w204 c63 2012
How can i buy this oil coolant.i send message on gmail
@SRG_C63
You have already rated this thread Rating: Thread Rating: 3 votes, 5.00 average.
Quick Reply: C63 AMG Oil Cooler solution! Reasonable 44O option!
