Battery or Alternator Issue?
do you still have yours unplugged and have you noticed any adverse effects?
Where is the battery sensor located and do I need to take any precautions or just pull it out when car is off?
If you're running a stock battery I'd leave it plugged in. Unless you want to unplug it for testing purposes it's located in the negative battery terminal. Just unplug the small sensor connector.
Thanks. I'm using a Varta G14 AGM battery, which I think is similar to the stock battery
