Any brake diagram out there?
I've got a brake fluid leak on my 2009 C63. I searched for a diagram to know what is the part number, without success. Is it a pain to change (I'm not talking about the bleeding part of the job)?
Also, would you use a brake line union (not a compression fitting)?
Am I right to assume that the diameter is 4.75mm?
Picture has been taken at the rear of the front left wheel.
Thank you.
The line goes from ABS unit all the way to either left or right caliper. It's not a hard job at all, I spent more time bleeding than replacing line, oh the line will come unbent though so you have to bend and route it yourself. I can't find my receipt for part no. though but as I said MB looked it up easy for me.
I tracked the part number and bought the line from the dealer and to my surprise, it did not come pre-bent and I had to buy the special tool and bend it myself.
I really was disappointed that MB did not bend them from the factory for that car.
But back in the '89s, maybe some lines were bent on the assembly line by workers ?? I don't know.
