C63 AMG (W204) 2008 - 2015
Lug Bolts for Edition 507; 19 inch wheels
Old Apr 7, 2020 | 03:26 PM
JumboNate's Avatar
2015 (Final-Year) Fully-Loaded W204 M156 Custom Mercedes-Benz Designo C63 AMG Edition 507 Coupe
Question Lug Bolts for Edition 507; 19 inch wheels
Dealer wants $230 for all 20 black lug bolts. Is this right?
Additionally, through some research and searching, I was able to find these:
https://www.mbpartscenter.com/oem-pa...olt-0009908307
(Description: Coupe, ... without C63.) ??
https://otisincla.com/product/rad-lu...l-seat-hex-17/
(Not black)
https://otisincla.com/product/14mmx1...cromet-coated/
(Also not black. Same dacromet coating. What's the difference?)
https://otisincla.com/product/m14x1-...th-54mm-black/
(Black! No dacromet coating...?)
Old Apr 7, 2020 | 03:46 PM
BLKROKT's Avatar
2012 P31 C63 Coupe Trackrat, 2019 GLE63S Coupe Beast
You can’t go wrong with Otis
Old Apr 7, 2020 | 04:14 PM
Mort's Avatar
Otis has these in black. (I see you already listed them....sorry )
Old Apr 7, 2020 | 04:32 PM
roadkillrob's Avatar
Top Answer: 1
12 C63BS Magno Alanite Grey, 25 X5 Msport, 08 BMW E93, Ducati Hyper 698
I did the 20 keyed gorilla locks in black for mine cheaper than $230, 48018NBC was the set I think, they also have a black chrome lug for $4 or so each 18018BC (black) so $80 for a set.
Old Apr 7, 2020 | 05:51 PM
saint13's Avatar
2013 C63, 2014 G550
Consider converting to wheel studs if you're going to be buying new hardware. Makes life SO much easier for taking wheels on/off, can accommodate spacers and they look pretty cool.
Skip titanium IMO, steel works great and is cheaper/safer.
https://motorsporthardware.com/produ...ud-kit-14x1-5/
Old Apr 7, 2020 | 06:44 PM
JumboNate's Avatar
Is this the correct size for my original 19 inch wheels?
Old Apr 7, 2020 | 06:45 PM
JumboNate's Avatar
Absolutely!
What I'm confused about are the differences in sizes between the lot.
What will fit my original 19 inch wheels properly?
Old Apr 7, 2020 | 06:56 PM
BLKROKT's Avatar
R14 ball seat M14x1.5 27mm length
Old Apr 7, 2020 | 07:02 PM
G_Money's Avatar
'04 E55 (Gone but not forgotten), '13 C63 P31 (RIP), another '13 C63 PP
+3 on Otis!
I definitely see mounting wheels being easier with studs, like if you are switching off to track wheels every weekend but if you have spacers or change wheels with spacers say every season or 2 (new wheels, different offsets and spacers) wouldn't lug bolts be somewhat better since you can change length easily vs studs?
Old Apr 7, 2020 | 09:44 PM
Mort's Avatar
Yes they are the correct size for the original wheels.
BLKROKT gave you the correct specs in his post above. Get the HEX 17 head bolt size for the socket as the HEX 19 sockets can be too large an outside diameter to fit into the wheel wells the bolts fit into in the wheels.
Old Apr 7, 2020 | 10:41 PM
AdrnlnRush's Avatar
2014 C63 507 Edition
You might think this is a cheesy answer but look up wheel bolt nut caps on Amazon and pick a color. For just over $10, you can cover them and if those look like crap after a while they are easily, and cheaply replaced.
Old Apr 8, 2020 | 12:52 PM
JumboNate's Avatar
I ordered the black ones! I've got a set of new tires sitting in the garage awaiting installation. I decided to replace the current lugs, as they are rusting.
I was confused on 'total length' with the black one being 54mm, and the other being 48mm. I guess we'll find out and see? lol
Old Apr 8, 2020 | 01:25 PM
Texas E63's Avatar
Built 2008 G55 & one big 80 Series LandCruiser !
ESC Tuning also stocks titanium options at a reasonable price......might as well save some weight while you can......
Old Apr 8, 2020 | 02:10 PM
Mort's Avatar
The important dimension in length is the shank length. The OEM shank length is 27mm. The 54mm overall length will mean that the head of the bolt and ball seat section will be a little longer or shorter and protrude out from the wheel seat a little more or less. This will not be a problem. You will see a little more of the bolt head.
Old Apr 8, 2020 | 05:05 PM
saint13's Avatar
2013 C63, 2014 G550
Originally Posted by G_Money
+3 on Otis!
Really depends on how different your wheel/spacer setups are from each other. I went 82mm studs and can run anything from 0-25mm spacers comfortably so a winter/summer setup is really easy. If you're trying to run bigger spacers than that during the summer and have a winter setup without spacers then dedicated bolts for each would likely work best.
Old Apr 9, 2020 | 11:44 AM
JumboNate's Avatar
Hey man, I really appreciate your response. This made total sense to me. Thanks a bunch
