C63 AMG (W204) 2008 - 2015
SOS! weistec sc low rpm jerky
Old May 25, 2020 | 04:39 AM
kevinlovepoyan's Avatar
c63 507
hi guys..
my car is 2014 c63 with weistec s2 sc. MBH lth and akapovic mid-rear exhaust. ECU tune is TPE tuned and it is good.
stock idle rpm is around 700-750. car just jerky climbing up a slope on low rpm.
so my tuner increase 100 rpm on it..but did't solve the issue.
i'll attatch the video clips...
hopefully someone could tell what is going on....thx..
Old May 25, 2020 | 04:29 PM
hachiroku's Avatar
SPONSOR
2007 Mercedes E63 AMG
go back to your tuner. it all falls back on the tune.
__________________
-BARRY
​​​Follow us on instagram @eightysixtuned
https://www.eightysixtuned.com
Old May 25, 2020 | 04:56 PM
deadlyvt's Avatar
2010 C63 AMG
Sounds pretty bad to be honest hard to tell from the Audio but sounds like some kind of mechanical clicking? Runs good other than at idle?
Old May 25, 2020 | 07:06 PM
mr747's Avatar
c63
tune issue
Old May 26, 2020 | 12:54 AM
c63 507
yes i guess so..i'll be back to him....
Old May 26, 2020 | 01:06 AM
c63 507
i don't think it's cliking on body after several check at the first time...yeah..tune runs good and safe for about 2 yrs...i ll find the dyno sheet for u guys on here..
Old May 26, 2020 | 01:07 AM
c63 507
Originally Posted by mr747
tune issue
tuner add 100 rpm on idle but same issue happens...
Old May 26, 2020 | 01:12 AM
c63 507
dotted was NA years ago and solid line is SC for now...same car same dyno
Old May 26, 2020 | 01:18 AM
c63 507
another video...is more clear to hear and watch...i used to have mbh x remus cat back setup..but didn't meet this issue or maybe it had happened but too slightly to notice...
Old May 26, 2020 | 03:52 PM
hachiroku's Avatar
SPONSOR
couple of things...
  1. what is up with your tune where you have a HUGE dip in power in the lower RPM's...
  2. from the sound of it without seeing the tune file, it sounds like you're running PIG rich.
__________________
-BARRY
Old May 26, 2020 | 04:06 PM
SikC63's Avatar
2001 E430, 2014 E 350, 2012 C63 PP30
When was the last time you switched out the spark plugs, 02 sensors, or replaced your MAF sensors? The car sounds like its running super-rich and not getting enough air. This can be caused by failing sensors preventing airflow to the motor.
Old May 29, 2020 | 09:04 AM
c63 507
couple of things...
i have no idea of the dip for my tune...BTW another tuner says so that the fuel is running wrong like u guys said..i use dashcmd app to log and i'll attach it...pls have a look for me and i'll be very appreciated..
Old May 29, 2020 | 09:05 AM
c63 507
Weistec spark plug and new o2 sensor replaced back in 2yrs ago...
pls check my datalog file thx.
Old May 29, 2020 | 09:43 AM
c63 507
log no.1
car going up the slope
https://datazap.me/u/kevinlovepoyan/...?log=0&data=21
log no.2
drive on the road as usual feeling wrong somewhere but can't tell what ....
thx guys need ur help and advices....thx..
Old May 31, 2020 | 04:28 AM
c63 507
Old May 31, 2020 | 09:33 AM
immelman's Avatar
C63 AMG
Put a new set of plugs in it, it’s time anyway. I had the porcelain fail on one of my plugs with only a few hundred miles after a s/c install.
Old May 31, 2020 | 11:28 AM
roadtalontsi's Avatar
10 C six trizzle
So car has ran great for 2yrs with this setup. Or new issue since new setup was just installed?
I'm going to go with needs a new mct unit. shockingly not that expensive on the parts side but trans has to come out.
However air / fuel issues will cause this if the adaptations are out by more than 1%
