C63 AMG (W204) 2008 - 2015
Rear tire wear
Old Jun 10, 2020 | 09:06 PM
Adi-Benz's Avatar
2010 C300 4MATIC........ 2011 C63 AMG.............. 2015 CLS400 4MATIC.....
Rear tire wear
Hi guys,
So I'm running Conti DWS 06 tires, and I'm down to the cords on the inside. Now, I did have an alignment a little too late and had some bad uneven wear - obviously it didn't even out, but I think the inside still has very accelerated wear? (I did get it done @ dealer) I am aware of the stock camber but am wondering if the stock camber causes this for you guys?
I know that K-mac sells kits and I think there are some oem "extra?" Camber bolts, but I don't remember this being an issue on my stock setup, only my aftermarket thus far.
Any ideas appreciated
Old Jun 10, 2020 | 09:09 PM
toosteeley's Avatar
Present: 2019 C43 Estate
What were your rear toe settings? The likely culprit.
Old Jun 10, 2020 | 09:22 PM
Adi-Benz's Avatar
Found my picture
So the right rear is showing a tiny bit of cords right now and left rear is pretty darn close too.
Old Jun 10, 2020 | 09:38 PM
deadlyvt's Avatar
2010 C63 AMG
Yes you stil have a lot of toe on the rear (factory sets it this way) take most of the rear toe out and you will wear even
Old Jun 11, 2020 | 08:58 AM
Jasonoff's Avatar
Top Answer: 3
2010 C63 AMG
1/8" toe in is quite a bit for a street car. Stability exiting a corner under power is not worth constantly cheese grading the rears. Zero that out.
Old Jun 11, 2020 | 09:29 AM
Adi-Benz's Avatar
So, correct me if I'm wrong but they actually significantly *increased* toe in the alignment?
Old Jun 11, 2020 | 11:42 AM
Jasonoff's Avatar
Top Answer: 3
2010 C63 AMG
Yes, "toe in" was increased.
Old Jun 11, 2020 | 01:45 PM
Adi-Benz's Avatar
I appreciate your help guys.
Here's where I am a bit confused - I had cupping in my rear tires with the alignment at the top of the page in the picture. The tech was aware of this so I'm not sure but wouldn't this then have been the complete opposite solution to the problem?
And, can I adjust these myself without the machine, or do I risk screwing it up completely?
Old Jun 11, 2020 | 01:51 PM
deadlyvt's Avatar
2010 C63 AMG
Unfortunately most guys who work at the dealership don’t know much other than follow what a book says or put the car within spec. Cupping is usually something bent or worn out but yes increasing the toe In is definitely not going to help
Old Jun 11, 2020 | 02:21 PM
sventastic82's Avatar
2010 C63 AMG RIP. 2021 Toyota Tacoma TRD Off Road, 2013 C63 coupe
Found my picture
toe in wears the outside of the tire down.
toe out the the inside.
the reason your tires wore on the inside is because you had it too neutral or toe out.
Do not adjust it keep it where it is.
your before toe is the reason why the tires wore so fast on the inside.
Old Jun 11, 2020 | 02:34 PM
No you will not wear even if you take toe in out. The inside of the tire is wearing that means too much toe out.
If the alignment on the rear tires is set to neutral toe in will flex to toe out under acceleration and will wear the inside of the tire.
Old Jun 11, 2020 | 03:57 PM
Xavier Smith II's Avatar
2010 C63 AMG, 2015 GL450, 2018 GLS 550, 2021 GLS 450
Hi guys,
i don’t mean to hijack the thread but how do you like your tires overall? Would you buy those again? I have P Zeros that are getting quite bald.
Old Jun 11, 2020 | 04:35 PM
Adi-Benz's Avatar
I love them! If you're up north or have lots of rain to deal with they're pretty good, but if you're south you could probably go with some more aggressive compounds. They do have a high tread rating - but in this case I can't really say they lasted as long as they should, but not really the tires fault.
Just curious do the rest of you guys run 2 pairs of rears for every 1 set of fronts (lifetime?)
Old Jun 11, 2020 | 04:37 PM
Adi-Benz's Avatar
90k maybe time for rear shocks eh (nothing is bent, car rides fine/sits fine/handles well)
Old Jun 11, 2020 | 05:06 PM
deadlyvt's Avatar
2010 C63 AMG
could be I had some cupping on one of my front tires when I changed them and went over all the suspension and alignment settings and couldn’t spot the culprit either but I did notice my shocks are getting to the point of needing a replacement guess it’s time for some kws
Old Jun 11, 2020 | 06:10 PM
Honro's Avatar
2011 C63 AMG P31
Get these, and call it a day.
http://ultimatepd.com/amg-w211-e55-t...n-set-119.html
Old Jun 11, 2020 | 06:14 PM
Adi-Benz's Avatar
Wow those look great but pretty pricey lol
Here's a pic of my current rear-right wheel
Dumb question but you can see there's lots of tread on the center...is there still life left for these or should I switch now
Also wouldn't camber be contributing to this moreso
Old Jun 11, 2020 | 06:18 PM
Honro's Avatar
2011 C63 AMG P31
Yep, there not cheap, but if it saves you one set of tyres, then they have paid themselves off. I was replacing rears almost twice a year, nearly every 10k kms. On my current set after installing them, sitting at 14k kms, and no sign at all of inner ware. Already paid them selves off for me.
These cars just run too much negative camber from factory, these are really the only way to correct it.
Good luck.
Old Jun 11, 2020 | 06:55 PM
Jasonoff's Avatar
Top Answer: 3
2010 C63 AMG
Sure, if negative camber wasn't part of the equation.
Lol maybe if he was at max acceleration 24/7...
With the current camber settings and 0 toe he would still get inside wear because of the camber, but, his tires would last longer than leaving the current positive toe setting.
Old Jun 11, 2020 | 06:56 PM
deadlyvt's Avatar
2010 C63 AMG
yes it’s the combination of a lot of camber and toe. You have most of the vehicle weight riding on the inner tire and then then the high amount of toe making the two wheels in effect driving in towards each other creating a scrub like effect on one another
Old Jun 11, 2020 | 08:02 PM
lol lol....
pretty much under any acceleration he will have negative toe and that under torque and weight transfer where the tires wear out the most.
take a look at this video there you can see how much the rear suspension flexes under acceleration.
6:20 shows it the best. I know it’s not c63 but I would expect similar results.
negative toe will wear out the inner edge of the tire and not just the inside like with negative camber.
the rear alignment needs positive toe in combination with negative camber.
for the front Alignment that is a different story neutral toe would work just fine unless it’s a 4wd or fwd car.
Old Jun 11, 2020 | 08:16 PM
For some reason I can’t see the picture of your rear tire.
you can pick up some adjustable rear camber arms for $180 on eBay.
Old Jun 11, 2020 | 09:09 PM
Jasonoff's Avatar
Top Answer: 3
2010 C63 AMG
lol lol....
http://youtu.be/axeCpTpMKcc
Here's nearly 3 seasons of wear on my rears with zero toe and I beat on it every chance I get.
Practical > theory every time brah...
Old Jun 11, 2020 | 09:17 PM
Adi-Benz's Avatar
Lol, if the mb techs see that sheet:
"OmG hOw dO yOu eVeN dRiVe tHis iTs UnAliGnEd"
-$6000 alignment
Old Jun 11, 2020 | 10:08 PM
deadlyvt's Avatar
2010 C63 AMG
I have almost the same alignment specs and the same results tire wear is even and I get almost twice the mileage out of the rears that I did with the factory specs
