C63 AMG (W204) 2008 - 2015
507 LSD, not on my data sheet but car acts as if
Old Jun 29, 2020 | 01:06 PM
Weapon507's Avatar
W204 c63
This is NOT just the same old lsd question. I searched..seems 507s did not come with lsd standard and it must be on the vin data sheet as its own option if car has it. BUT my car leaves 2 even black tire marks when I take TC off and acts as though it has lsd, but it is not on the data sheet Joe just decoded for me on the VIN thread. I bought the car with 4500 miles on it from a dealer who got it through an estate sale. Not one modification to the car that I can tell, but no lsd option on data sheet and 2 black tire marks during burnout leaves the only conclusion that original owner added lsd and absolutely nothing else to the car. Previous owner cannot be contacted.
Thoughts?
Thx
Old Jun 29, 2020 | 01:32 PM
BLKROKT's Avatar
2012 P31 C63 Coupe Trackrat, 2019 GLE63S Coupe Beast
An open diff can still leave two tire marks. If it ain’t on the build sheet you don’t have one (unless the previous owner installed one).
Old Jun 29, 2020 | 01:51 PM
Savage-wp's Avatar
2014 Mercedes C63 AMG 507 Edition
My 507 could also leave 2 black lines when it was stock with no LSD.
If it's not on the datacard, then it wasn't fitted by the factory.
Maybe previous owner fitted an aftermarket LSD.
Old Jun 29, 2020 | 01:58 PM
Weapon507's Avatar
W204 c63
And twisting the rear tires while car is off the ground is the definitive check to see if aftermarket was installed without pulling diff cover?
thx
Old Jun 29, 2020 | 02:47 PM
ecohen2's Avatar
thx
This is by far the easiest way to confirm whether you have an LSD or not and only takes about 15 minutes to do... Plus it doesn't wear out your tires!
Old Jun 29, 2020 | 03:40 PM
roadkillrob's Avatar
Top Answer: 1
12 C63BS Magno Alanite Grey, 25 X5 Msport, 08 BMW E93, Ducati Hyper 698
This for sure, just jack it up and turn one side and see which way the other side turns!
Old Jun 29, 2020 | 04:30 PM
Weapon507's Avatar
W204 c63
Thank you. It will be on a lift next week, we will check it out. Much appreciated
Old Jun 29, 2020 | 04:45 PM
skratch77's Avatar
2005 E55
Make sure u put in in N
Old Jun 29, 2020 | 05:05 PM
Weapon507's Avatar
W204 c63
Roger that, don't want my next post to be 'tires won't turn is it broken?' Lol
Old Jun 29, 2020 | 11:47 PM
C63AMGeez's Avatar
W204 C63
thx
Pretty sure the stock lsd only locks upon acceleration. So doing that still won’t give you an answer.
Old Jun 30, 2020 | 04:42 AM
DRBC43AMG's Avatar
So no option code 471 on the data card then?
Old Jun 30, 2020 | 07:24 AM
skratch77's Avatar
2005 E55
My p31 didn't come with a limited slip but I installed one. So you probably have one the owner installed.
Old Jun 30, 2020 | 09:04 AM
Weapon507's Avatar
W204 c63
Thx for the replies.
Hey skratch can you verify on your lsd c63 whether the jack up and rotate tires method works to determine lsd? Thanks
Old Jun 30, 2020 | 09:05 AM
Weapon507's Avatar
W204 c63
not that I saw, have a look if you like, its one of the most recent ones on the vin thread
Old Jun 30, 2020 | 09:34 AM
skratch77's Avatar
2005 E55
Yes it does. It was the first thing I did on mine.
Old Jun 30, 2020 | 10:29 AM
Weapon507's Avatar
W204 c63
Very helpful. Thank you
Old Jun 30, 2020 | 10:31 AM
Weapon507's Avatar
W204 c63
Data card
did not see 417 LSD option on here
My rear axle code says HA
File Type: pdf
Old Jun 30, 2020 | 12:45 PM
sventastic82's Avatar
2010 C63 AMG RIP. 2021 Toyota Tacoma TRD Off Road, 2013 C63 coupe
Yes it does. An open diff lets the tires spin in opposite direction. With an LSD the tires spin the same direction.
Old Jun 30, 2020 | 04:57 PM
hachiroku's Avatar
SPONSOR
2007 Mercedes E63 AMG
an open diff doesn't mean you aren't able to leave 2 black marks or even do donuts...if you have enough power and your weight is evenly distributed either is possible. getting your rear in the air and spinning your driveshaft while holding one wheel will let you know if you have something.
__________________
-BARRY
​​​Follow us on instagram @eightysixtuned
https://www.eightysixtuned.com
Old Jul 8, 2020 | 12:19 PM
Weapon507's Avatar
W204 c63
Just wanted to follow up since you all were kind enough to respond. My 507 was up in the air this morning, they did the tire spin test and it has an open diff, not an lsd.
Renntech is the closest high quality shop to me by far, 5 miles away, but their 100% locking diff is way more expensive than other options and they won't install a brand other than their own, claiming they had issues with installing other diffs in the past. I have gone with all their stuff so far and the quality is high, that price though lol.
FYI:
The general idea of my 507 is to just get as much performance out of it as I can, while keeping it fully streetable, naturally aspirated and 93 oct pump gas. So I have tried to use the best quality parts thus far because I think the cars warrant it..i am at 480+whp/430+wtq with stock resonator, stock secondary cats, stock mufflers. Car is quiet and peaceful in Comfort mode and wakes up like a beast in S+ and M. Happy with performance so far and only a couple minor issues with the Renntech stuff though it was pricey.
Old Jul 8, 2020 | 01:25 PM
PeterA90's Avatar
c63
FYI:
the diff they use is amazing. Os giken is badass!
Their parts are pricey. I have their tune and I’m happy with it and my Mbh headers.
what issues did you have with them?
Old Jul 8, 2020 | 02:38 PM
Get that. DIY or have a decent transmission shop do the swap. It is not new but usually outlasts the car anyway.
Old Jul 13, 2020 | 12:44 AM
J0HN_R1's Avatar
'19 4runner TRD / '12 C63 AMG
Originally Posted by sventastic82
Get that... DIY or have a decent transmission shop do the swap. It is not new but usually outlasts the car anyway.
Well telling him (and everyone else) where he might find "that" OEM diff could be beneficial.
I can't see any distinguishing features of the ad / picture to say otherwise... As to where to buy "that".
Old Jul 13, 2020 | 12:51 AM
J0HN_R1's Avatar
Double tap...
Old Jul 13, 2020 | 04:37 AM
G_Money's Avatar
'04 E55 (Gone but not forgotten), '13 C63 P31 (RIP), another '13 C63 PP
Pretty sure that's ebay...
