My W204 M156 C63 smokes at high reves and chows oil, but it doesn't smoke at idle.
Smoke at startup is pretty common on these cars from fuel in the exhaust, has happened on both of mine if say I am washing it and start it and back it out of the garage and shut it off, then wash it then start it and put it back in the garage, then the next startup hours later or the next morning will have some grey smoke from unburnt fuel in the exhaust from starting it a few times cold and shutting it off before it warms up. So may be unrelated to the oil consumption issue or could be valve stem seals, which I have not heard of a lot.
I hope you get some help.
I have a high mileage m156 120k
Car runs fine and it oil chows oil like it's nothing.
700 miles in car will burn more then about 2L
I filled the dip stick to the max. About 200 miles it the dip stick level already when down about 0.5L
mix city driving a high way. 70% city 30% highway.
Mix driving between hard acceleration and normal driving.
there no smoke when driving, only on cold start and car has been sitting.
I have no clue what this could be at this point.
I have a catch can and new pcv. Catch can has oil every 1000 miles, almost half full.
valve stem seals have not been touch. Bore scope looks great.
