How to Disable Fuel Pump?
I’d try the 40A fuse hanging off the positive battery terminal in the plastic holder with only one other fuse. (my car had a 25A in there which blew and killed power to the fuel pump, either way it’s the smaller of the two fuses you want to pull)
FCPEuro somehow managed to ship me the oil change kit without the filter so now that sets back my plans for this weekend
Worked beautifully. Couple things to note: after pulling the fuse, start the car up again to burn the excess fuel in the lines before draining the oil. Also, after cranking the car for (3) 10 second intervals you will get a check engine light for a P06xx code (can't remember the exact code). Just grab your OBDII scanner and clear the code, all is well. Massive thank you again to BLKROKT!
It's absolutely no different than letting your car sit for a few days.
I can understand for a turbocharged car wanting to get oil flowing through the bearings first, but for our engines think it’s totally unnecessary.
Engine builders usually use an external auxiliary oil pump to build pressure.
