C63 AMG (W204) 2008 - 2015
C63 AMG Wheel Fitment
Old Aug 21, 2020 | 01:54 AM
  #51
BLKROKT's Avatar
2012 P31 C63 Coupe Trackrat, 2019 GLE63S Coupe Beast
This site is even clearer about the results. http://www.gtsparkplugs.com/WheelOffsetCalc.html
Every inch change in wheel width is worth ~13mm in offset change (wheel width in inches, offset is in millimeters, 1”=25.4mm).
So if I change my wheel width in back from 10” to 9”, I’d want a +39 offset to keep the outside lip in the exact same plane as it’s in now (reduces total width by 25.4mm, divide that in half you get the 13mm that you need to shift the wheel center line back out, push the wheel out is lower offset, so you get 52-13=39), but that also means I would have a huge gap to the strut. That’s essentially what you’re asking about.
So a +38 will likely work fine for you depending on tire width (you may have to trim the bumper clip), but it’s pretty far from an ideal fitment.
Old Aug 21, 2020 | 02:15 AM
  #52
alion94's Avatar
2010 Mercedes-Benz C63 AMG
Every inch change in wheel width is worth 13.5mm in offset change (wheel width in inches, offset is in millimeters, 1”=27mm).
So if I change my wheel width in back from 10” to 9”, I’d want a +38/39 offset to keep the outside lip in the exact same plane as it’s in now (reduces total width by 27mm, divide that in half you get the 13.5mm that you need to shift the wheel center line back out, push the wheel out is lower offset, so you get 52-13.5=38.5), but that also means I would have a huge gap to the strut. That’s essentially what you’re asking about.
So a +38 will work for you depending on tire width (you may have to trim the bumper clip), but it’s pretty far from an ideal fitment.
yeah, I think I’m going to go with the Niche Rainers M240s... 19x8.5 +42 and 19x9.5 +50... Thank you for explaining some of the stuff on there... Like I said, I’m dealing with this shop thats giving me a lot of back and forth answers and there trying to convince me on the 20x9 +38... I made the mistake of mentioning 20s to them in the first place... oh well.
Old Aug 21, 2020 | 02:41 AM
  #53
BLKROKT's Avatar
BTW it’s also worth noting that I do run aggressive offsets, so YMMV. Just wanted you to have the info and tools to make a decision. @Roswell would have probably been the best guy on fitment issues like this but he hasn’t been around for awhile. @Mort will probably correct me here if I’m wrong.
Old Aug 21, 2020 | 11:14 AM
  #54
Hsg08's Avatar
MB W212, MB W218, BMW F06, BMW F48
https://mbworld.org/forums/market/789911
You could’ve bought these wheels and tires for almost the same price.
Old Aug 21, 2020 | 11:17 AM
  #55
alion94's Avatar
they look good, not my style though :/
Old Aug 21, 2020 | 05:05 PM
  #56
alion94's Avatar
Asking one more time, 19x9.5 +50 in the rear of my 2010 Mercedes c63 amg will work? I have stock 18x8 in the front and 18x9 in the rear. There saying 50 may be cutting it close, they suggested +38.
fyi, these are concave wheels... Niche Rainer M240.
Old Aug 21, 2020 | 06:05 PM
  #57
Texas E63's Avatar
Built 2008 G55 & one big 80 Series LandCruiser !
My build to spec before widebodying were 19x9.5 et 48 rear with a 275/30/19 - 255 in front on 19x8.5 et 40
those were spot on. ET50 might work..... might.
Old Aug 21, 2020 | 06:12 PM
  #58
alion94's Avatar
what about the tire size with 19x9.5 +50 with 255/265 ... /30/19
niche recommended front 19x8.5 +42 paired with rear19x9.5 +50.... but I don’t believe them cause they also said 20x10 +38 would work in the rears with 285/35/20.
Old Aug 21, 2020 | 07:22 PM
  #59
Cwagon's Avatar
2013 W204 C63 AMG P31 Estate wagon
19x9.5 +50 with 265/30 will fit no problems
Fronts 19x8.5 +42 with 245/35 will be perfect.
Old Aug 21, 2020 | 07:25 PM
  #60
alion94's Avatar
perfect, shop is finally working with me on selling my old tires and providing free services... so ima do this setup. I also called several places who said the same thing! Thank you guys all for your help. I’ll post some pics once it’s all done.
Old Sep 16, 2020 | 12:50 AM
  #61
Airspeed1's Avatar
2011 c63
forget about any rear wheel that has less than 45 offset.
Even with a 45 offset rear you would need to run a 255 tire to "maybe" clear the outer fender so no gain in rubber on ground.
With option 2 above you can run 245/35x19 on front and 275/30x19 on rear, No Rubbing.
this is correct info
