LTH and E85
anyone know if weistec supports bigger injectors with tunes or EC the only one?
Also if you change injectors, yes you need to fully tune for that.
Ethanol has a different stoich ratio so your car cannot automatically adjust for it as at e85+ you need to use about 30-40% more fuel so your afr will be extremely lean without a tune.
ok no your wrong. You don’t need a tune if you have a flex kit. I have had eurocharged flex kit also known as fluid dynamics kit for 3 and a half years with 550 cc injectors. I think I know what I’m talking about. I also have headers and catless mids. The reason you don’t need a tune is because the flex box adjusts the fueling based on the ethanol reading it receives. This is the benefit you can run whatever blend you want. I run full e85 all the time. Except in the winter when my car sits in the garage. I add an ethanol additive every fuel up too. I have an e85 tune however I typically just run my normal 93 euro charge tune no issues what so ever. There are some cars that auto change the tune based on 93 vs e85. This is not one of them. You can run e85 with out a flex kit however your tune needs to be spot on fueling wise and you better know your exact E number. The flex kit simplifies everything and gives you more flexibility. I would recommend not getting the cheaper kits guys buy. Those are the only ones I’ve seen people have issues with. Contact eurocharge atx for the kit. Haven’t had any issues with mine.
https://mbworld.org/forums/c63-amg-w204/781803-e85-preparedness.html
mbworld.org/forums/c63-amg-w204/651192-flexfuel-everyone-eurocharged-atx-e85-kits-now-available.html
yup my next step (Full E85 Tune).. thankfully, i have a VP Racing station right be the home, so availability isnt an issue. Plus its not a daily driver
Cut my fuel costs in almost half, got some good power. No doubt I'd do it again
You also don’t need to contact eurocharged for a kit. All they are gonna do is add 250+ dollars on top of the kit with injectors. The injectors you seek are part number 0280158123
Just make sure your kit has EV1 harness connection
Side note your fuel trims will never be correct. Those kits don’t run very well. 80-85% at best. When your trims aren’t correct you’ll lose power.
Also, it’s not hard to monitor your e content. All you need is a sensor and gauge. If your tune is meant for e75 and you have e60... you will have knock and detonation. There’s really no point in running race gas running 93 timing. Waste of time, I’ve done it.
if you want more power than that you’ll need nitrous or supercharger
As the guy above mentioned. Fuel trims will always be wrong. that's a hard pass.
On your supercharger you greatly benefit from even an e30 blend. I’d be surprised if you didn’t get 30+whp without even tuning the car. Full e85 FI cars gain 70+ with proper tuning and fuel support.
As I said before, e85 on the car with no tuning will feel lackluster. The Bosch computer is going to be fighting itself to correct trims. This will lead to inconsistency on how the car feels. Also, e85 will require much more timing because of the burn rate. Most wont understand this car their car might drive fine. But go against a properly tuned car and you’ll be surprised.
Also, the people who have trouble in cold start with e in colder weather is because your cold start fuel map needs to be rebuilt. Eurocharged, weistec, oetuning, does not offer that. They simply change the load tables, add 3-4 degrees of timing everywhere and hopefully the Bosch takes care of the rest.
Custom tune, headers, e85 will yield phenomenal results for an N/a car.
