Strange M156 Noise
E63 owner here but there is much better info / knowledge of the M156 in this forum so I hope you don't mind me posting. I just sent my E63 to my brother (who lives in Las Vegas) and he noted this "knocking" noise when revving it up a bit. It's not the injector tick at idle, it's a loud knock you can hear clearly at the 9-second mark of this video. Please let me know what you guys think is going on. The car has been on LM 5w40 for 6k miles and I had not heard this noise before. No codes or other symptoms.
Thanks,
Cyrus
See the two posts below
https://mbworld.org/forums/c63-amg-w...ml#post8145469
https://mbworld.org/forums/c63-amg-w...ml#post8146675
If it is just doing it constantly and wasn't sitting I would pull the valve cover and have a look, only takes a couple hours to see what is going and feel better about it.
That also sounds like an up to temp engine (could be wrong) so the bucket should have pressurized by then. That and the fact it's not as obvious at idle it doesn't sound like a bucket that needs to fill with oil.
I might suggest a mechanics stethoscope or even just your ear to to identify the location of the noise as that will help tell what it is also.
Cam Adjusters typically rattle on a cold start until they get oil pressure and then quiet, once they wear enough they just rattle always - noise at the very front of the head.
Buckets from bleed down - typically make noise after it sits on a cold start, more likely the longer it sits, will go away once oil pressurizes the bucket and fills it, I have had this take sometimes 15-20 minutes of driving, seems to somehow be better if you run for a few minutes and shut off and start again - tends to get quieter with revs also.
CA's you really can't tell visually without taking them off and taking them apart, if the noise is further back on the head, then pulling the cover to inspect is worth doing.
Worn out bucket/cam - will just make the noise all the time warm or cold and not usually go away with revs although may get quieter with revs.
Thanks,
NM.
If you do the lifters, make sure they use the updated SLS part number, it is what the old part numbers supersede to for all M156 engines and have a coated top which helps with the wear and they have improved oil valves to keep the oil in the lifter.
Cheers,
N
My guess with the adjuster is that it’s infinitely variable and the pin unlocks from engine start allows for good fuel economy when keeping below 3500 rpms and good power above 3500 rpms.
