C63 AMG (W204) 2008 - 2015
More Light output
Old Sep 28, 2020 | 03:36 PM
Xavier Smith II's Avatar
2010 C63 AMG, 2015 GL450, 2018 GLS 550, 2021 GLS 450
More Light output
I recently moved out into the sticks, and I’m looking for ways to increase Light output. As I understand it, HIDs are the best for light throw, are there any HID kits for our fog lights or High beams?
Old Sep 28, 2020 | 04:45 PM
blurred's Avatar
2013 C63 P31
Aren't the OEM low beams already HID for your model? If not that is the first thing to upgrade to new HID headlights.
Next, make sure to have them adjusted properly, usually they are set too low and need to be raised up slightly. If they are already HID, aimed well and the bulbs haven't been changed in a few years you can put new basic ones in or get new upgraded HID bulbs. Philips Xtreme Vision Gen2 would be the best to use.
Then move on to upgrading High beams, fogs will only hurt your distance vision in pitch black at night.
Old Sep 29, 2020 | 08:06 PM
Yes they are already HIDs for the low beams, can the High beams be upgraded to HID? Without any other adverse reactions?
Old Sep 29, 2020 | 11:35 PM
roadtalontsi's Avatar
10 C six trizzle
not all C63 came with xenons standard. It was an option so there is the potential it does not have them.
Old Oct 1, 2020 | 09:24 AM
blurred's Avatar
2013 C63 P31
HID for high beams is not a good idea as they have warm up time and ballasts do not like hot re-starts unless they are oem. You should first get your low beams set up well, make sure the lenses arent cloudy toe-nails, inspect inside the projector to ensure the bowls havent been burnt and then get new bulbs.
For high beams you could try led but its hit or miss and will likely not give any additional distance, only brighter close to the car which will hurt your distance vision.
Old Oct 1, 2020 | 09:48 AM
INS1GNIA's Avatar
'13 C63 AMG P31
I remember seeing a post a while back about a light bar, you could always give that a try. Still somewhat stealthy but looks like pretty good extra light output.
https://mbworld.org/forums/c63-amg-w...ah-i-know.html
