Need Aftermarket Rear Suspension Help/Recommendations - Uh-oh! Incident
I’m just saying that you should consider cutting your losses before this turns into a money pit. Because it will. That’s just too much damage - it’s got to be well over 1/3 of the blue book value if not 1/2. And it won’t ever be right.
And also that a nice car is not something to trust a kid with not ruining. It’s just a fact of life, not trying to preach.
I skipped over this thread when posted because I figured the entire back end was destroyed and the car would be totaled. Is insurance covering somehow or is it out of pocket? It just doesn’t make sense to me to fix. If I were you I would use all OEM parts, forget about coilovers, get it as straight as you can and sell it.
Or, you can dump a ton of money and time into it and always be trying to track down why it doesn’t drive straight or why the tires wear funny. You might be able to get it right eventually but at what cost.
I don’t know. But I wouldn’t start thinking about aftermarket anything until you can make sure it can be properly fixed back to OEM spec. Just my 0.02, good luck.
Thanks Again.
General Opinion: The car took a pretty massive impact evenly across the back either at launch or at landing. No one can really believe the resulting damage is so localized.
In all seriousness though, very carefully run your hand down the c-pillar between the back of the door and rear window and feel for any even small ripple and look at all the body gaps around the rear of the car between the doors trunk and body, with an impact this hard I would be worried about the body structure being damaged.
