Lots of smoke from engine bay after short drive
Best regards,
trester
Could also be intake manifold gasket leak, although that wouldn’t cause smoke.
Maybe both. Or valve cover could be leaking oil on manifold.
Could be many things, need to dig in.
immediately there was smoke coming from the back of the engine, it came out mostly on the drivers side but definitely from back of engine and not from oil burning on manifold since this was seconds after starting the car and everything was cold still.
the dentist drill sound also came on immediately so this is caused by a bad PCV valve and not the fan that's supposed to come on at high temperatures thats been suggested in another thread about that issue.
Can a bad PCV valve also cause smoke?
Your intake is probably swimming in oil, I hope not. I'd remove the intake manifold as well to clean out any excessive oil.
Others will hopefully give you better info to go by.
