C63 AMG (W204) 2008 - 2015
Headers Install Problem - Tightening Rear 2 Upper Nuts
Old Aug 12, 2021 | 06:06 AM
xKryptonite's Avatar
C63
Headers Install Problem - Leak + Tightening Rear 2 Upper Nuts
Hi everyone,
Back to the C63 platform after a few years I’m installing VRP headers and I’m having an issue tightening the 2 upper rear nuts in the passenger side (rear as in closer to the collector). How did you guys reach those? The only tiny space I can see is between the primaries and a 11mm wrench barely fits. I’m attaching a couple pictures for reference (not mine). Any tool or extension you might suggest?
Thanks!
Old Aug 12, 2021 | 07:06 AM
swedepat's Avatar
2011 C63 AMG, 589hp
I used an ordinary 11mm spanner
search: https://www.google.com/search?q=ring...w=1440&bih=836
But i had my engine loose(not standing on enginemounts) and moved the engine as far as i could to each side to get some room for my rather large hands.
Old Aug 12, 2021 | 09:17 AM
deadlyvt's Avatar
2010 C63 AMG
I used a 11 mm wrench and with one hand holding the wrench into the nut and the other hand rotating the wrench I slowly got it tight.
there’s an angle you can get your arms up in there fairly comfortably. I also had the engine loose and jacked up a bit to get at it.
Old Aug 12, 2021 | 09:25 AM
lekoza's Avatar
2013 c63 AMG P30 Coupe
I bought various 11mm sockets and extensions to install my headers. I also had to use a snake camera on a couple of the bolts to see the angle and get the sockets onto the bolts. Was a major pain in the *** and a couple of the bolts took about a half an hour each.
Old Aug 12, 2021 | 05:29 PM
BLKROKT's Avatar
2012 P31 C63 Coupe Trackrat, 2019 GLE63S Coupe Beast
Buy an 11mm ratcheting flex-head wrench and an 11mm offset wrench. It’ll make your life a lot easier.
I also remember finding some crazy angle going through the wheel well to get at a couple. Might want to get the car in the air and remove the fender liners to have a look if you haven’t already.
Old Aug 12, 2021 | 11:03 PM
AMGonFire's Avatar
2012 c63 AMG, 2011 GLK 350, 2019 GLS 450
Pay someone lol best 550 I ever spent.
Old Aug 13, 2021 | 12:45 AM
BLKROKT's Avatar
$550 is a fukin bargain for headers install. I’d take that deal in a heartbeat. One of the worst 8hrs spent in my life.
Old Aug 13, 2021 | 04:22 AM
C63
I was able to get one of the 2 upper nuts sorted. Now there is one left and I can’t even put the nut in place to tighten it. Impossible! On top of that, 2 nuts already fell in between the primaries and it’s impossible to get off unless I take the headers off (hell no at this point lol). Is that gonna be an issue (vibration or knocking?).
I’m already paying someone who has his garage. I would pay someone $550 to get all done. I’m in Portland, Oregon so I can pretty much do Oregon or Washington (Seattle area is 3 hrs away) but no one wanted to do it or they’re 2/3 months away to take it in. Summer is done by then :/
Old Aug 13, 2021 | 05:27 AM
swedepat's Avatar
2011 C63 AMG, 589hp
Magnetic pickup tool?
My nuts were just coated with copper, so if oem nuts they are magnetic.
Old Aug 13, 2021 | 02:18 PM
C63
They’re OEM. They fell in between the 2-1 collector and there is no clearance to guide the magnetic tool. I’ll give it a try a few more times and see how it goes.
Old Aug 14, 2021 | 06:17 AM
C63
During the install the guy broke the clock spring 🤦🏻‍♂️ He saw the steering wheel moving freely and he said he connected everything so he turned it one spin and *creek*.
I have 2 problems aside from that. I think there is a leak somewhere (I left the guy who was installing the headers for 2 hours earlier and he put on the VRP gaskets instead of the OEMs I bought). Are those leaky? Can someone tell me from the video if what I say is correct? He says there is no leak but I’m 100% there is a leak. Listen to the videos please.
In the second video (engine bay area) there is a high pitch/whistle noise (this was present prior to the headers). Is this the PCV? I did take the oil dipstick out but it still remained there.
File Type: mov
File Type: mov
Old Aug 14, 2021 | 06:36 AM
G_Money's Avatar
'04 E55 (Gone but not forgotten), '13 C63 P31 (RIP), another '13 C63 PP
I didn't listen to the vid but an exhaust leak is like a tick tick tick hiss, not a constant his.
