C63 AMG (W204) 2008 - 2015
Hydrolocked! :(
Old 02-09-2022, 06:43 AM
  #76
swedepat's Avatar
2011 C63 AMG, 589hp
The red circles marks two alignmentholes i did a mistake putting there.
but no harm done, it works anyway, i just added two new in the correct place.
Old 02-11-2022, 07:03 AM
  #77
swedepat's Avatar
2011 C63 AMG, 589hp
Hardened and heattreated, just checked with 600 grit paper if they had warped anything.
I have left some to take away later today(0.4mm) when i rig them to the surfacegrinder, but i was curious after hardening the surface was good, no problems as you can see.
I put the 600 grit on an absolute flat surface (diabas stone) and rubbed the plates against the paper.
And i measured axial inside the phasers, 0.05mm; this divided into 2 will be 0.025mm at each side, well enough for oil to get in there.,
Old 02-11-2022, 10:23 AM
  #78
swedepat's Avatar
2011 C63 AMG, 589hp
There!, Done! just a small touch to get correct lubrication before install. HRC tested and surface grinded to correct dimensions.
Was at my friend who makes connectionrods and drysump pumps for a lot of highend racers on the globe, a lot in the states also. He surfacegrinded the plates, the only thing i didn´t do on these. And cost so far? About 10 bucks in total (for the fuel in my pickup for visiting my friend).
Old 02-12-2022, 04:58 PM
  #79
swedepat's Avatar
2011 C63 AMG, 589hp
Anyone changed the seals on the triggerwheels?
I noticed there was a little bit of wear on mine, and as Go Team mentions it is really important to get the phasers working correctly i figure i can´t have any unwanted leaks.
Old 02-13-2022, 04:42 AM
  #80
go team's Avatar
2012 C63, GL63, 1989 300CE
We stock these. 🤣
swedepat (02-13-2022)
Old 02-13-2022, 12:30 PM
  #81
swedepat's Avatar
2011 C63 AMG, 589hp
Can´t find them on your site.
How to order?
Old 02-13-2022, 02:00 PM
  #82
swedepat's Avatar
2011 C63 AMG, 589hp
Engine is back in, but far from finished as you see.
A little downtime due to i need to order new seals for the triggerwheels, engine is assembled just so any dirt wouldn´t find it´s way into it when i put it back in the car.
But i´ll order them tomorrow(monday)
In the meantime i can mount a lot of small things, i'm also changing transmissionfluid again, just might aswell, as the car is on stands
Old 02-14-2022, 01:53 AM
  #83
SPONSOR
hachiroku's Avatar
2007 Mercedes E63 AMG
what material are the factory ones? and where can one buy replacements?
__________________
-BARRY
​​​Follow us on instagram @eightysixtuned
https://www.eightysixtuned.com
Old 02-14-2022, 02:18 AM
  #84
swedepat's Avatar
2011 C63 AMG, 589hp
Oem the material seems to be very brittle like cast pistonrings, very much alike the sealing rings inside a turbo.
The new ones i don´t know what matrial they are in, they seem to have some coating thou.
I called dealership this morning, can´t be bought separate from the 'bushing'.
I just placed order from Poland, about 1300skr(~140$) complete with shipping(4 complete kits)
Look for a company called 'mehenker'
Old 02-14-2022, 09:25 AM
  #85
BLKROKT's Avatar
Received 2,827 Likes on 1,670 Posts
2012 P31 C63 Coupe Trackrat, 2019 GLE63S Coupe Beast
Originally Posted by go team
We stock these. 🤣
I’d start with @go team as he actually seems to know what he’s talking about
Old 02-14-2022, 12:37 PM
  #86
swedepat's Avatar
2011 C63 AMG, 589hp
Have i been wrong anywhere of your knowledge?
Only thing in this debacle i was 'wrong' about was a alignment hole that i just mirrored, my bad but i told you all about it.
I just figure i got a horn in your side since my comment of your carbonwrapped enginecover.
I have been nothing but patient with you, but you keep trying to make fun of me, and that just ends up in me doing the same to you.
Get over it, grow up and be a man!
And a hot tip!
Stay out of my thread and you will be happier, you can´t get rid of me.
Old 02-14-2022, 08:05 PM
  #87
SPONSOR
hachiroku's Avatar
so...that was my understanding as well, they're metal. they're like piston rings. but the photo you posted shows them in plastic? or is that painted metal?
__________________
-BARRY
Old 02-16-2022, 12:53 AM
  #88
swedepat's Avatar
2011 C63 AMG, 589hp
I would say it is a coating, mine are on it´s way so i can tell you in a couple of days =)
Old 02-16-2022, 11:08 AM
  #89
sventastic82's Avatar
2010 C63 AMG RIP. 2021 Toyota Tacoma TRD Off Road, 2013 C63 coupe
Those rings are most likely made of PTFE (teflon) with a filler like glass or brass.
They seem to be hydraulic wear ring just like in industrial applications.
Old 02-16-2022, 12:10 PM
  #90
swedepat's Avatar
2011 C63 AMG, 589hp
We'll see tomorrow.
That company also offers regeneration of old ones with 24 month guarantee.
IF the life span is let´s say 25months with daily usage of the car, they will hold up for me about 6years
I only use my car about 4.5-5month a year
And if they become a problem, i´ll make my own rings(in steel)
Old 02-16-2022, 02:54 PM
  #91
SPONSOR
hachiroku's Avatar
its been about 2 years since i've looked at one in person so they may very well be some kind of polymer. share photos when you do get them.
__________________
-BARRY
Old 02-17-2022, 01:49 AM
  #92
swedepat's Avatar
2011 C63 AMG, 589hp
Yes, later today.
It´s still morning here, i´m collecting them at postoffice after work.
Old 02-18-2022, 12:29 AM
  #93
swedepat's Avatar
2011 C63 AMG, 589hp
The are made of some sort of plastic.
Fits perfect though
closeup.
Old 02-18-2022, 12:32 AM
  #94
swedepat's Avatar
2011 C63 AMG, 589hp
They are very lightweight and has less tension then oem steel rings.
But the overall outer diam are a little bigger so i figure there are more 'press' on the ring, and thereby creates a good seal, and also the ends are butting up to each other harder.
hachiroku (02-18-2022)
Old 02-19-2022, 10:29 AM
  #95
swedepat's Avatar
2011 C63 AMG, 589hp
I´m jiddering in Swedish, But just a video of startup.
I´m talking about the smoke from the headers(some oil)
And later i´m pointing out that the fluid on the floor isn´t from startup.
It´s coolant from when i put the radiators in, and oil from when i changed the seals on the triggerdiscs.
(a red motul oil i had lying around.)
Everything went fine.
Engine feel more sealed up than before as the fillercap really is sucked down
BalanBro (02-19-2022)
Old 02-19-2022, 03:57 PM
  #96
Cwagon's Avatar
2013 W204 C63 AMG P31 Estate wagon
Did you use any special procedure to bleed cooling system.
The MB method looks very complicated and needs special equipment.
Old 02-20-2022, 01:15 AM
  #97
swedepat's Avatar
2011 C63 AMG, 589hp
Actually no, just burping it with squeezing the hoses.
And later on when the thermostat had opened i kept rpm at ~2000rpm for a while.
I might have to keep an eye on temp later, but as is for now it seems to work, the heater works and temp is under control, fan starts and shuts off.
Cwagon (02-20-2022)
Old 02-20-2022, 03:35 PM
  #98
Cwagon's Avatar
thanks
Old 02-22-2022, 04:01 AM
  #99
swedepat's Avatar
2011 C63 AMG, 589hp
Now back to what i was planned to do this winter. The front fender got a small touch from the wheel as i said earlier, fixing that. At the bottom of the doors and at the rear of rear door there was some stone chips(dunno what it is called) At the top of the doors it leaved some marks when i took away the trims. I figured i´ll fix all this in the same run at the paintshop.
Almost done.
Old 03-29-2022, 02:00 AM
  #100
swedepat's Avatar
2011 C63 AMG, 589hp
Finally at paintshop. Season is getting closer, but fuelprice is just insane in Sweden. Soon up against 10 dollar per gallon. I also decided to repaint the wheels(not the ones on pic) They are 'bronze', but i feel that satin black is more suitful to white.
Also, engine so far seems very very ok, no codes no leaks no nothing, running smooth as f**k after injectorchange and having the engine apart for checkup.
The following 2 users liked this post by swedepat:
catmandoob (03-29-2022), WidowrRacing (03-29-2022)
Quick Reply: Hydrolocked! :(
