C63 AMG (W204) 2008 - 2015
Camshaft Adjuster Plates - Aftermarket Replacement??
Old Aug 26, 2021 | 08:06 PM
strider-g3's Avatar
87 420sel, 91 560sec, 02 S55 AMG, 09 A4 3.2, 14 Outback, 12 Focus SE
Hey all, my vehicle is in for headbolts and the camshaft (intake) adjusters are skipping. I need to replace both and I am wondering if anyone has ever bought the adjuster plate itself and replaced that piece only?
I am also being given the option to refurb / rebuild that plate by another shop that says they would just weld and ensure the gap on the plate is correct again so the pin doesn't slip out like its doing now. Is that a bad idea?
I have no scoring or marks on the lobes and the valve buckets are good as well.
Cost of new cam adjusters is $2200 CAD
Cost to refurb each adjuster is $120 CAD
The shop says they won't guarantee the work if I choose to go with the refurb option..
Videos to show them skipping:
Old Aug 26, 2021 | 08:14 PM
Jasonoff's Avatar
Top Answer: 3
2010 C63 AMG
https://www.63motorsports.com/m156-s...haft-adjusters
Old Aug 26, 2021 | 08:17 PM
strider-g3's Avatar
From my understanding, its just the plate that wears down where the pin sits and lets the pin slip, am I correct?
Old Aug 26, 2021 | 08:19 PM
strider-g3's Avatar
Thanks for sharing. Have you used their parts?
Should I go this route and spend the extra dough or just get the existing plates refurbed?
Car is at the shop already on their hoist and they want to put it back together asap as the new headbolts are in already!
Old Aug 26, 2021 | 09:00 PM
C63AMGeez's Avatar
W204 C63
I just bought stage 2 CA plates from 63motorsports and will be doing this myself next week. Best to get the plates from these guys and be done with it. Getting a refurb or new set will eventually cause the same issues again.
Old Aug 26, 2021 | 09:39 PM
roadkillrob's Avatar
Top Answer: 1
12 C63BS Magno Alanite Grey, 25 X5 Msport, 08 BMW E93, Ducati Hyper 698
Generally yes the pin is very hard and wears the hole in the plate into a teardrop shape, the 63motorsports one are hardened so they wear less and come with new pins also and should last a lot longer and are a lot cheaper than new CA's.
Old Aug 27, 2021 | 02:00 AM
Cwagon's Avatar
2013 W204 C63 AMG P31 Estate wagon
I fitted stage 1 plates & pins to mine about 4-5 months ago and has run perfect since start up.
https://www.63motorsports.com/m156-s...sters/p/stage1
Am very happy with their price and service even to Australia.
Old Aug 27, 2021 | 09:05 PM
Ragunarok's Avatar
C63S Coupe
How much did the install cost?
Old Aug 28, 2021 | 05:23 AM
Cwagon's Avatar
I did the install/changeover myself in my driveway during my cars last service.
Beside the plates, only cost me in gaskets, oil, filter etc from FCP Euro.
I already had the cam timing tool from when I fitted new lifters just after I purchased the car in 2018.
Old May 28, 2024 | 04:54 PM
E63Zurix's Avatar
E63 AMG
Which plate did you guys get?
There’s three options the street, circuit or competition
