Purchased a REALLY low mileage 6.208L - Future Proofing
I found, and negotiated a purchase of, a 2011 E63 with 21,800 original miles. Oil changed once a year regardless of mileage or every 2500mi. Knowing what the community now knows about the M156 engine, how would you recommend future proofing basically a 'new' engine? Meaning, what would be your thoughts on going ahead and pulling the valve covers and replacing the tappets with the SLS Black options, replace the valve adjuster lockplates with units from 63 motorsports, injectors, etc. so that I minimize the chance of the common issues 10 years from now? Or is it a just a matter of time no matter what? I'm ok with either, just weighing options now.
As always, thanks!
Also the headbolts should be switched out as well
Have the upgraded buckets been viewed as a permanent solution or just a longer wear item that will eventually need replacing?
Being that the cams are somewhat a problem with the original lifters it is possible the cams could still cause a problem but like I said haven’t heard if that yet.
