Need advice... Mechanic ruined my car
Also, if someone can please explain what might have caused this to happen, if it was the work the shop did, etc, that would be great.
The shop is located in Houston Texas. The car only has 45k miles, and had the supercharger on it for about 5k miles
The car was misfiring at high rpm, they could not pinpoint the problem, so decided to take the supercharger off and see if it fixed the issue. The shop is saying because the heads were so warped, the car wasn't able to have too much pressure and blow up like it did earlier, and that after surfacing the heads, it caused all the pressure to build up and that is what ultimately caused it to blow up. As well as the shop claiming the supercharger damaged the rings but the motor only has 45k miles
The M156 doesn’t have replaceable sleeves. The cylinder walls are coated with a very thin layer of something similar to HVOF, which is about as hard as Tungsten Carbide. The carbide can be ground out and resprayed, but it’ll cost about $1000 per hole to finish grind, if you can find a machine shop with the right machines and willing to do it.
My guess is that the PCV is blocked and/or not plumbed up correctly causing crank pressure to build. But anything is possible I guess considering that this individual had the heads off.
I think you can plan on a lawsuit. Unfortunately, anything you get here would be inadmissible and totally useless.
You need to tell them to cease and desist any further activity with your car in writing.
You need to collect your car and take it to a reputable Indy shop to get someone who knows what’s going on to look at it and determine exactly what happened. You need their words in writing for it to hold up in court. You need to save every written word of exchange between you and the shop that messed your car up.
Timing would not have contributed to crank case pressure, or if it did, it would have had to be so far out that you’d have much more serious problems, and it wouldn’t have run at all.
Also, you can’t “notice” a head is warped simply by looking at it. You need a precision straight edge and precision measuring equipment such as a feeler gauge, etc...
If a head is bad enough to be warped just at a sideways glance, it would not have been something that was a surprise. You’d have known something was ****ed up.
I think they ****ed your timing up, smashed a bunch of valves, and took the heads off to fix it while “fixing the warpage that they conveniently discovered in passing.”
If the smash was bad enough, it would have damaged the cylinder walls to the point of causing blow by and excessive crank case pressure, which they would have discovered after putting it back together having hoped for the best.
IMO, they owe you an engine.
I really appreciate your input, thanks. Any idea what would have caused the crank pressure to increase so much? Is what they're saying about the damaged rings from the supercharger possibly true?
"If we were to put a used engine in it yes. Basically what happened is the super charger caused a lot of internal damage that didn't show up until we started trying to save the engine. Now we have excessive crank case pressure that the pcv system can't handle and it basically pulling oil into the intake and causing the misfiring and also the leak from the passenger side valve cover. With the heads not sealing it was only causing misfires but now the top end is healthy so the pressure has to go somewhere."
I think the only way the boost could have damaged your engine is from a tuning issue. If it was detonating or running lean it could have melted a piston, but that would manifest with its own symptoms, none of which you have mentioned.
I think the crank pressure issue is caused by a mistake they made during assembly, or by damage they caused before disassembly.
The courts aren’t going to care whether or not the initial install of the S/C was done properly or not even if you could prove it. It’s an aftermarket mod which isn’t OE approved.
superchargers don't warp heads...and burning of oil could be because your PCV was bad. superchargers introduce a lot more blowby through the crankcase in comparison to a standard M156. if you had that much blowby that the valve covers were spitting oil when they shouldn't have, that means your rings are shot or you have a blown motor.
Two trans??
Anyways you’d think the first course would be to check compression and leak down test before pulling heads. Just sounds like they screwed up somewhere in the process and I agree trying to fight this with aftermarket parts installed voids any argument. I’d get more details on their findings depending on how advanced the shop tools go. Whats concerning is you went in with concerns of lean codes and misfiring and ended up with worn rings? Also I’m sure if oil in the intake was causing your misfires you would’ve seen excessive smoke out of your exhaust.
They are saying the crankcase pressure was excessive after the repairs, and said that after resurfacing the heads is what caused the other issues to finally show up with the worn piston rings.
Whether it was a bad tune, too much crankcase pressure from the S/C, bad workmanship at the shop or any combination thereof is irrelevant at this point. With warped heads I suspect that you'll likely need a new engine. As others have said, the M156 has no sleeves - the cylinder bores are twin-wire-arc-spray coated during manufacturing (basically it's a metal vapour deposition) that result in a very hard but also very thin metal coating (about 4-5 mils), and there isn't enough material to be honed without getting into the soft metal which would make rebuilding it futile, and if the heads are also warped you'll unfortunately need a whole new motor (long block). The only way to know for sure what needs replacing would be to tear down the engine, but I suspect that it would be considerably cheaper to get a used engine that is (hopefully) in good mechanical condition than to start building an M156 with a new engine block while trying to salvage whatever parts may still be usable from yours even if the crank, rods and pistons are still serviceable.
