C63 AMG (W204) 2008 - 2015
CEL/P0014 Code After Replacing Cam Adjuster
Old Nov 14, 2021 | 09:20 PM
pww92's Avatar
2011 C63 AMG
Hey guys, did the switch on my worn cam adjuster plates last week - for a few days after i was getting a CEL / P0014 code (shown below) but after getting an OBD2 scanner to read the code, its seemed to have gone away (I made sure not to clear the code)
Any idea what could be causing this and whether I should still look into it now that the code's gone?
Old Nov 20, 2024 | 01:16 PM
Eduardo JV's Avatar
Hey man, I'm facing this problem as well on my C180 2012, after change the timing chain and timing chain gears, rails and tensioner, after some days got P0014, it sometimes fade away and then appears again, the car is working well despite this error and check engine light is on, I have no clue what cause this, I wonder if maybe the ECU learned the timing chain modifications over usage and wear of parts, and now it recognize that is out of thresholds or something like this, or the mechanics installed wrong or something like that, but I'm searching for responses yet.
Old Mar 17, 2025 | 10:22 PM
mickey91!'s Avatar
Fixed?
Did you find the solution to this code?
Old Mar 18, 2025 | 12:00 AM
roadtalontsi's Avatar
10 C six trizzle
time the camshafts correctly. that is the fix.
Old Mar 18, 2025 | 01:12 PM
0fc5dccf's Avatar
Make sure you installed the right plates in the right camshafts. Intake and exhaust plates are different, but will bolt up and install "fine". Make sure you timed the engine using the timing tools and crank at 40*. Make sure you did a re-learn afterwards as well.
