Need Mercedes Front & Rear Subframe Bolts Torque Specs Please
Can anyone get me the print out instructions from Mercedes for the front & rear subframe bolt torque specs. I have seen over the last few years people have been able to get the print out instructions/diagrams and specs and upload them for other things.
I will need them shortly when installing the Spoon ridged collars.
2012 P31 C63 Coupe Trackrat, 2019 GLE63S Coupe Beast
Here you go, these should help. Most of the subframe bolts are 80nm.
Not sure if the Rigid Collars are doing anything, but I buy the theory so why not. Before you install make sure you’ve done anything you need to do with the subframe lowered, like upgrading roll bars, subframe bushings, etc. Although I’ve reused mine, and I have a backup set, they should really be replaced if you raise/lower more than once or twice.
Thanks, Ive got kw coilovers, adjustable drop links, kmac rear adjustable arms/toe bush/front camber bushes and now going to order the ridgid collars, Like you have said I cannot see how they would not benefit as they fill a void in the subframe bolts locations.
I was also looking at the ultra racing bracing bars which look like they can be fitted anytime as nothing has to be removed? It looks like you just remove the bolts and fit.
Will the subframe have to be dropped to replace with the Wavetrac?
I thought you could not get the eibach anti roll bars anymore? Did you have to drill the adjustment holes on the end too?
Like you said I am looking to get everything done all at once where I won’t need an alignment and corner balancing again.
