C63 AMG (W204) 2008 - 2015
Insoluble substance in coolant reservoir
Old Feb 24, 2022 | 05:05 PM
apoptosis's Avatar
C63 AMG
After a quick drain and fill on my 2014 with 59k, I noticed this insoluble oil in the top of my reservoir. I used distilled water and oem Mercedes concentrate to make 50/50. Removed reservoir to clean any debris and rinsed with distilled before reinstalling.
I do use a very small amount of dielectric on the hose flange to aid in removal in the future. My coolant level stays consistent and with the small amount there is I may be overthinking this. Any input is appreciated!
Old Feb 24, 2022 | 05:22 PM
BLKROKT's Avatar
2012 P31 C63 Coupe Trackrat, 2019 GLE63S Coupe Beast
I don't think that's enough of anything to worry about
Old Feb 24, 2022 | 06:13 PM
hachiroku's Avatar
SPONSOR
2007 Mercedes E63 AMG
not enough...but a certain number of radiators installed by mercedes and from an aftermarket supplier were faulty and failed causing coolant leaking into the transmission fluid. if you think its transmission fluid, swap out that radiator and do a flush of your transmission and coolant asap.
__________________
-BARRY
​​​Follow us on instagram @eightysixtuned
https://www.eightysixtuned.com
Old Feb 24, 2022 | 08:11 PM
apoptosis's Avatar
C63 AMG
That's interesting I've never heard of that before. The transmission fluid looked good when I changed it last spring. I'll flush the system and replace the reservoir in a few months. Pretty sure I'm overthinking it!
Old Feb 25, 2022 | 01:06 PM
hachiroku's Avatar
SPONSOR
not 100% sure but i don't think it affected the W204 C63 but always something just to keep in mind with any aftermarket radiator.
__________________
-BARRY
Old Feb 26, 2022 | 01:51 PM
HLG600's Avatar
2009 SL63 AMG
Agreed that it's unlikely to harm anything, but if I noticed this on my car, I would try to extract it with an industrial syringe. Clean baseline and close monitoring afterwards.
Old Feb 26, 2022 | 03:04 PM
apoptosis's Avatar
C63 AMG
That's a good idea! I'll remove as much as I can with a pipette and monitor it over the next few weeks.
Old Feb 27, 2022 | 06:34 AM
DRBC43AMG's Avatar
Yes there were some issues with radiators from Valeo found in the W202 series, if I'm not mistaken
