C63 AMG (W204) 2008 - 2015
Stearing shaft replacement question ….
Old Mar 22, 2022 | 04:14 PM
ertech's Avatar
mercedes 71 280sl. Porsche 930 . Ducati mh900 and ps1000
Hi Guys
I have a Knock sound from the steering and all suspension is tight
was told it could be the shaft
should U replace part A or B?
Which part is usually responsable for the knock.
Old Mar 22, 2022 | 08:00 PM
BLKROKT's Avatar
2012 P31 C63 Coupe Trackrat, 2019 GLE63S Coupe Beast
LOL anyone who answers this is just guessing. I practically guarantee whichever one you end up replacing, the opposite one will be the culprit…
Old Mar 22, 2022 | 08:41 PM
AMGSPY's Avatar
2014 C63 507 Coupe
Check out / search N I L (1320' NA Build). He has a really good post on doing this with a parts comparison too.
Old Mar 22, 2022 | 11:57 PM
roadtalontsi's Avatar
10 C six trizzle
its probably going to be the in column, that isn't available separately.
Old Mar 25, 2022 | 01:53 AM
NZ-Merc's Avatar
W204 C200, BMW E30 M3, 1980Gt Mini, Toyota Corona, KTM 200 EXC.
Hi
Pictured above is the last part you would replace looking for a knock, start with replacing the sway bar links first and take it for a test drive if still there then replace the caster arm and lower arms.
Old Mar 25, 2022 | 07:53 AM
ertech's Avatar
It’s more like loosened in steering
