C63 AMG (W204) 2008 - 2015
M156 "Stage 3" Cams
Old Jul 12, 2022 | 01:17 PM
  #101
sickSVT's Avatar
Top Answer: 1
3.0L Whipple E63 AMG
Originally Posted by lekoza
Just noticed your car made a brief appearance in this video. Did you ever get dyno results?
Pretty cool to see a clip of the car in the video.
No dyno or track #'s yet, it's been 100*+ degrees weather in Texas for the last 2 months so just been enjoying driving it to local car meets.
Did get some new tires, billet engine and trans mounts. Once the weather cools down the car should be ready for the track.
Old Jul 19, 2022 | 01:48 PM
  #102
E63007's Avatar
07' E63
I must give you credit for busting the move on the build yourself! As far as the sound is concerned, if that’s your preference, go for it, but I’ve never just liked loud sound for sound sake. When viewing your video around town when you opened it up under the HWY Crossing, it didn’t appear the the MPH jumped as violently as it sounded. With that kind of loudness, one would expect the rear wheels to light up and mph to jump as well! To each their own, I guess. I personally couldn’t drive around with my car set up like that or my PIA/POA would have a cow!
When I did my rebuild, I had my heads rebuilt and it turned out 8 of my Intake Valves were bent and they measured all the springs and replaced a few of them too! As such, I’m not looking to undertake that again any time soon. Yes I used the New Headbolts! However, since my Cams have 100k mi on them, they are something I’ve been researching ever since I did my rebuild. I just didn’t have the coin to bust a move on them when I had the heads out the first time! I mean, don’t get me wrong, my 07’ E63 performs marvelously, but even though I did spring for the SLS Tappets, and the Cam Journals “looked” good from even my Head Builder’s perspective, I just know from a preventative maintenance standpoint that I would be well served to get them swapped out sooner as opposed to later! As such, the recommendations of WebCam for the Cams themselves, and Cam Motions to get the OEMs spec’d out is very useful information indeed! Not to mention, E63 Motorsports for their Cam Adjuster Plates & Oil Filter Cover & DipStick! And a shout out to Xtreme Headz in Palm City,Fl and RMT in Pompano for their hefty Intake Plenum as well their whole OEM Intake rebuild as well as their OEM Rebuilt AirSprings all around!
Old Jul 19, 2022 | 03:09 PM
  #103
sickSVT's Avatar
Top Answer: 1
That video was one of the very first test drives around town with very mild throttle pulls to make sure everything was good.
I'll get some new videos but I can easily make my RR drag slicks light up from the hit.
Old Jul 19, 2022 | 08:26 PM
  #104
Cwagon's Avatar
2013 W204 C63 AMG P31 Estate wagon
What size were your old Toyo's and wheel size?
I quite like the baggy look over the stretched look that most go for.
Old Jul 19, 2022 | 08:43 PM
  #105
sickSVT's Avatar
Top Answer: 1
295/30-19 Toyo's run a bit wide. They barely clear my rear fenders without any rubbing.
The R888R's didn't hook very well for me so I switched to RR's. They seem to grip better.
Old Jul 20, 2022 | 11:27 PM
  #106
Cwagon's Avatar
What size rear wheels are you running?
Old Jul 25, 2022 | 12:24 AM
  #107
sickSVT's Avatar
Top Answer: 1
10"
Old Jul 25, 2022 | 06:19 AM
  #108
Cwagon's Avatar
Very nice, love the way it looks.
Old Oct 2, 2022 | 02:07 PM
  #109
E63007's Avatar
07' E63
Hey, just wondering if those first video’s on this post you took after the install of the Cams were representative of what the Cam Swap alone sounds like with the OEM exhaust set-up, or had you already made an exhaust modification? In other words, I’m curious to know if the difference from standard OEM sound was due solely by the Cam Swap, or by the combo of that + an exhaust Mod?
Old Oct 25, 2022 | 05:00 PM
  #110
the_indian_kid's Avatar
2008 MB C350 4MATIC/2011 CL63 AMG/2014 C63 Coupe 507
Loove the sound. Did you ever do a compression test after the cams were dropped in, outta curiosity?
Old Jan 10, 2023 | 03:10 AM
  #111
djr48312's Avatar
2009 c63
Here's a little side comparison between the custom spec cams and factory cams.
Dude that's noticeable more lift and alot more duration at high lift. What were the advertised specs?
Did you dyno it before and after and what are your impressions?
Old Nov 6, 2023 | 05:57 AM
  #112
Punkhu wu's Avatar
E63 wagon
Pls check pm
Finally got these bad boys in, had a shop custom spec these "stage 3" cams for me. Going to be doing a full top end rebuild with 63 Motorsports Plates, BS Lifters, Gaskets & Seals.
Can't wait to hear this thing chop!
im interested pls pm
Old Nov 7, 2023 | 01:34 PM
  #113
djr48312's Avatar
2009 c63
Have you ran it with the cams yet? Any descriptions? Curious in how it feels and if you plan on dynoing?
Old Nov 24, 2023 | 06:49 PM
  #114
AMGmann76's Avatar
96 c36/04 e55
Rebuilt
[QUOTE=sickSVT;8537284]Finally got these bad boys in, had a shop custom spec these "stage 3" cams for me. Going to be doing a full top end rebuild with 63 Motorsports Plates, BS Lifters, Gaskets & Seals.
[/QUOTE
what kind of money r u spending parts/labor if you don't mind me asking!!
Thx
Old Nov 24, 2023 | 06:53 PM
  #115
AMGmann76's Avatar
96 c36/04 e55
Exhaust
10"
What exhaust u running on the rear!
Supersprint nice but well out of my range,!
Old Nov 24, 2023 | 06:55 PM
  #116
AMGmann76's Avatar
96 c36/04 e55
Tires
I'm running 285's on mine....
Old Nov 24, 2023 | 07:07 PM
  #117
hooptierolling's Avatar
2009 c63
are you interested in selling your old cams?
Old Nov 24, 2023 | 07:29 PM
  #118
djr48312's Avatar
2009 c63
Sweet ride. Those new cams are certainly more aggressive than the old! I like the color too, obviously a custom paint job.
Old Nov 24, 2023 | 09:25 PM
  #119
AMGmann76's Avatar
96 c36/04 e55
Barry
Originally Posted by GarlicBread
Leave it to a one cammer to bring up lift size in any conversation...
his contact info
Barry!
Thx
Old Nov 24, 2023 | 11:52 PM
  #120
hachiroku's Avatar
SPONSOR
2007 Mercedes E63 AMG
Originally Posted by AMGmann76
his contact info
Barry!
Thx
not sure if you're asking about our contact info. its available on our website https://www.eightysixtuned.com or info (at) eightysixtuned.com
__________________
-BARRY
​​​Follow us on instagram @eightysixtuned
Old Nov 25, 2023 | 08:36 AM
  #121
Supersprint Sport Exhausts's Avatar
Former Vendor of MBWorld
Exhaust sale ....
Gentlemen, you may or may not know, SuperSprint is now having our Black Friday Sale which ends on the 28th. If there's anything I can do for you, please reach out to me. I'll do my best for you.
robert.c@supersprint.com
Respectfully,
Roberto
Old Jun 2, 2024 | 01:50 PM
  #122
AM_WE_G's Avatar
2012 C63 P31
No dyno graphs, I'll take it to the track once it's back up and running.
Give me a month or so and I will have a literal before and after. I'm about to dyno on Tuesday and then off she goes to get the cams installed.
Old Jun 2, 2024 | 04:08 PM
  #123
djr48312's Avatar
2009 c63
Did you have to roll or trim the inner fender for 285s??
Old Jun 2, 2024 | 11:45 PM
  #124
AMGmann76's Avatar
96 c36/04 e55
tires
Not on the e63, have 275 on e55, don't think 285 will work cuz the 275 r really close...with the niche wheel am using
Old Jun 3, 2024 | 09:48 AM
  #125
djr48312's Avatar
2009 c63
You have e63 with M156?
