C63 AMG (W204) 2008 - 2015
Headlights conversion to Facelift ..please help
Old Apr 15, 2022 | 10:17 AM
Cashrolling's Avatar
C63
Hi everyone, i need some help. I did lots of research but it just getting me more confused. What's the easiest way to swap headlights? Meaning the wires, connection and all that. I have xenon in my 2009 C63, but i wouldn't mind put in a facelift halogen or aftermarket. Is it possible?
ps: i already have a hood, and i don't change the bumper as i like the pfl one.
Just looking inputs on the headlights themself and the easiest way to make them work. I didn't buy any headlights yet cause i don't know which one would be easier to connect.
Old Apr 15, 2022 | 02:16 PM
INS1GNIA's Avatar
'13 C63 AMG P31
Your best/easiest bet would be aftermarket DEPO headlights. Plug & play.
DIY - DEPO Projector Install
More search results - Depo Headlights (Google Search)
Old Apr 15, 2022 | 02:46 PM
chrisridebike8's Avatar
'10 C63
If you don’t change the bumper, you will have a gap between the bottom of the headlight and the bumper. Good luck
Old Apr 15, 2022 | 04:54 PM
C63
But i do have Xenon headlights, doest it work same way?
Old Apr 15, 2022 | 05:07 PM
INS1GNIA's Avatar
'13 C63 AMG P31
I'm not sure what you're trying to accomplish as an end result? You mentioned about swapping headlights, DEPO are the best way to have the FL look/functionality (if that's what you're going for).
https://mbworld.org/forums/c63-amg-w...ft-xenons.html
Old Apr 15, 2022 | 06:25 PM
C63
From my research the main problem when changing from 2009 to 2012 headlights is the connection. The plug is different and you get erro codes. I'm not an expert in this at all, i just want the facelift headlights on my 2009, something that a normal electrician can be able to connect and make it work.
Old Apr 15, 2022 | 07:17 PM
INS1GNIA's Avatar
'13 C63 AMG P31
If you want to adventure into it - https://mbworld.org/forums/c63-amg-w...t-diagram.html
Old Apr 15, 2022 | 09:20 PM
C63
Thanks. It just sounds so confusing and complicated. Question since i have Xenon, can i buy the halogen facelift headlights and match those connections or i must replace them with xenon only?
Those threads are old, i was hoping by now someone made a plug in kit for this ...
Old Apr 15, 2022 | 10:07 PM
INS1GNIA's Avatar
'13 C63 AMG P31
Either you convert your front end to FL to accommodate the new headlights or you just have to deal with the PFL headlights (regardless if xenon or halogen). All the information is stated in the threads of others who were looking for the exact same thing. You'll have to make the judgment call if you want to tackle it or not after doing research.
C63 PFL xenon to FL search
Old Apr 16, 2022 | 05:26 AM
N I L's Avatar
C63
Many people will agree and disagree, PFL front end is much more aggressive in majority of aspects/angles vs the FL. Personally would continue to sport the PFL front grill as the lines contour with the bumper/headlamps
Following facelift components are required to accommodate FL headlamps properly without any gaps otherwise it'll appear salvaged (fascia, bumper structure supports, upper/lower grills, hood, hood accents, foglamps, hardware) $4-5K Once complete with decent paint/blending; at this point I'd integrate/emulate 507 accents. If you're still convinced Resistors/Re pin required to enable fogs/headlamps appropriately while dodging can bus errors.
$ave towards Mo$hammer Kit
