Finally complete. M156 Lock Plates.
When driving, this translates to a split second hesitation, poor throttle response only until the cams are finally returned to target range as seen by the cam position sensors and zero noise.
A google on “cam phaser failure” will return pretty much everything I’ve said and more.
The alternate cam position maps are there not just for cams “randomly” stuck in home position but presumably in other areas as well. The factors like poor oil pressure, component wear, oil loss (active bleed-out), etc. will all play into the infinitely variable parameters that the computer uses to maximize power.
But this points out what I’ve been calling out, if you want to avoid home position especially on the exhaust stay well above 2k rpm’s. And try to not load the car suddenly and abruptly from below this area if you’re stock. If you’ve got worn plates it will slip off on the exhaust side from the nature of the rotation of the cams.
Watch wording here as you’re correct during function car is under load and higher rpm’s. When the function is for emissions coasting and such it will reach zero and home position.
The cam vanes have two points for oil supply one for retard another for advance which is what is controlled by the solenoids. Both holes are on opposite sides there is a cutout on the vane for this.
That’s where duty cycle comes in. When it’s at zero or -15 degrees for the exhaust it’s against the leftmost wall so there’s no need to pressurize the left side when the car is calling for home position at a coast to a stop for example.
Everyone does not comment on the home section of the cam VVT maps or applications below 2k (emissions also applies outside of parked and idling).
So while the wording is correct it’s not the whole picture on datapoints and datasets. I could post home position while car is moving but why bother.
Regardless last post regarding this. Cheers everyone!
Both cold and warmed up?
Id like to see what your readout says.
As I’ve said, I know what the pulse width looks like on a scope, and it’s always varying. I can’t really drive around with a 75 pound O-Scope sitting on top of the engine, so I’ve ONLY seen it at idle.
The solenoids are hydraulic spool valves. In the neutral position they supply oil pressure to both advance and retard sides of the phaser to keep position.
Depending on probe polarity, a positive pulse will move the spool towards one side, feeding more pressure to one port, and bleeding off the other port. A negative pulse will move it the other direction, and reverse the pressure bias.
It comes raw from the Xentry with German headers. I think I had 6 pages which I cropped down to one. Let me see if I can find the raw file.
If not yes, I'll head out and grab a fresh log.
The Exhausts sit on -15 degrees and intake sits between 25 and 30.
Here's a graph, am working on the log.
In idle, revving without load, the cams stay put.
Revving with load by stabbing the pedal, the exhaust stays put, while the intake starts to move around.
What i was trying to do here was to have the log started with the engine off, then crank it while logging. Of course the Xentry lost initialization when trying this and therefore a time gap shows in the log. Nevertheless good data.
Still not convinced as there are nothing that turns camshafts to it´s home position when you shut off the engine, it is the first cranks before starting engine that returns camshafts to their locked position before oilpressure arrives and pushes out the locking pin again(it is happening with a fresh engine tenth´s of a second after engine have started)
And about lazy phasers, nahh.
This is just 'sales talk' from you to sell in your coating.
As there are no oildrain in the phasers they rely on the actual leak(and drainback into solenoid passages) that the greece guy showed us in a video.
If getting a totally sealed up phaser it would be really lazy as the pressure on different sides of the legs in the 'star' needs to push away oil on the other side
And as there are almost no metal contact inside the coating just makes no difference.
I have ran my own plates the whole summer now, no hesitation no nothing, and i made them all wrong somebody stated....
And finally about the map, the map is designed like this as engine is expected to have their phasers locked when engine has turned a couple of cranks before start.
In this way engine management quickly syncs and letting engine to start.
This is such a conversation about Home Position.
So, it's time someone defined in degrees what Home Position is.
It's also time that someone defined Locked Position, in degrees.
Home and locked is exactly as what Jan stated.
Intake 28 to 30 POSITIVE
Exhaust negative 15
here is a screenshot of me holding the idle at a higher rpm with the throttle pedal.
In German
Einlass Knockenwelle is intake cam
Auslass exhaust.
Anyway
If I Rev in idle even around 3000, but accelerating lightly, it holds the locked home position.
Home and locked may be the same physical condition, but they are not the same mechanical condition as evidenced by the pulse width on the solenoids.
As a tuner, you are giving the computer an instruction based in that neat little table in HPTuners, the computer has to translate that into PWM to the solenoids based on feedback from the CPSs.
Even at home position at idle, the solenoids are fluctuating to maintain position.
If it wasn’t so much damn work, I’d prove my point by assembling a set of adjusters without lock pins, and after the startup rattle, idle would be absolutely silent.
