Need a bit of help: P30 LSD main bearing failed
![Question](https://mbworld.org/forums/images/icons/icon5.gif)
Hey guys!
I am in the middle of upgrading my car with a custom blackboost camshaft kit and will post about that soon in my build thread.
However another issue came up that has gotten worse over the years, a grinding noise from the rear diff. I decided to have the diff rebuild and also change the diff ratio to shorten the gears a bit before driving around with extra HP.
Now two different shops have told me that the diff can´t be repaired since the main bearings in the p30 LSD can´t be bought as replacement parts, only the complete diff can be bought.
I have searched through this forum and found a few threads with similar issues, but haven´t found a clear answer so far.
Does anyone here know if it´s possible to get replacement parts for the P30 LSD? What broke is the "Hauptlager" which I assume translates to "main bearing"? Not sure if that is the correct term in english.
Anyway, I would really appreciate any help that I can get since I really don´t want to fork out 3k for a whole new diff.
Thank you guys so much in advance!
Alex
Alex
Carrier Bearing: 230 350 03 49
Pinion bearings are not listed as a spare part by Mercedes below is a link with their manufactures part number.
https://mbworld.org/forums/c63-amg-w...ml#post6563023
Pinion bearing
Pinion bearing
The following 2 users liked this post by sventastic82:
DRBC43AMG (07-28-2022),
The Extra Mile (07-27-2022)
Pinion bearing
Pinion bearing
that is exactly the Info that I needed
This is very interesting as I made the gears taller to stay within the gears more.
Hey guys!
Alex
Alex
I have a noise that sounds like the diff but I haven't been able to isolate it. Just found out about dyno mode, so that may help.
Received 2,827 Likes
2012 P31 C63 Coupe Trackrat, 2019 GLE63S Coupe Beast
Subbed. I’m also looking to go shorter to increase the effective torque and have more usable gearing on track. Interested to hear details as a few have done this but it was a pretty intense undertaking, especially getting the various codings to get along well.
Oh that might change things. I was under the impression that it is a purely mechanical change? The ecu and gearbox don´t "know" how the rear end is setup so what would need to be changed?
You'll want to find a tuner who is able to go in and correct that stuff.
The Extra Mile (07-28-2022)
Thank you so much for that! I will talk to my shop and see what they say. I don´t want to go through all that effort just to revert everything back to normal.
Changing the gearing itself is purely mechanical, but the computers are monitoring wheel speed. It expects to see the front and rear spinning at about the same rate in a straight line (calibrated for the circumferences of the original tires). If you change the final drive enough it's going to see a big difference in wheel speeds all the time, and may interpret that as a problem. And that may also affect the way the transmission operates.
I think I will just risk it and see what happens, for science! Worst case is that I have to go back to stock ratio. I really think that it would transform the car for the better and would not want to skip this.
Your car won’t run right without the appropriate coding. It’s not even mainly about the trans. The ABS/ESC system will flip out and be inoperable at best.
Oh just another quick thought, trying to think this through, the wheelspeeds would obviously not be different between the axles, otherwise I would do a permanent burnout haha. Just the RPM the engine would run at a certain wheel speed would slightly change, however that would be already the case for every single gear.
Wheel speed sensors. ECU and TCU coding is required. I don’t think the car will even move without it.
It would be like putting a much shorter tire on the rear.
@Celicasaur would be the guy to help answer this stuff if he’s still around. He went off the deep end on these questions.
In Vediamo it’s VGS 3 once you’ve changed the final drive ration (also in Vediamo). I haven’t programmed the changes yet but have mapped the areas where the change needs to be done. I can try to update with findings. But again I’m going taller gearing similar to these guys marketing it
https://www.premiertuninggroup.com/c...-65-ratio-ring
Why taller gearing?
Just an example in 4th on 2.65 you’re topping out at 239kph in 3.06, 207kph. Powerband has wider use vs needing to shift sooner.
For drag you still probably want 3.06 but for road course it would depend on the course. I thought the Burg would benefit from tall gears!
Interesting. Is this an MCT car?
