Help with finding a break kit
You're looking at about $1300 in parts (depending on which pads you go with). Maybe 3h of labor to do both F&R, although a competent mechanic should be able to do it more quickly.
If you're not comfortable doing it (which, no offense, I'm guessing is the case based on the challenge you had identifying proper parts), find an indy that's willing to use parts that you supply.
You should be out the door for $1750 or less.
All that being said, I might want a second opinion instead of trusting the dealer that both your front and rears (pads and rotors) all needed replacement.
Genuine MB Pads : https://www.fcpeuro.com/products/mer...amg-0054208920
