W204 C63 braking vibration and shuddering (Advice please)
I am experiencing a shuddering and Vibration when braking
After this i replaced both front discs and pads (ZIMMERMAN) twice from FCP and tried to run them in as best i could without overheating or keeping my foot on the brake when at a junction or lights etc. Initially i didn't notice the issue but i was careful on my brakes for a good 400 miles.
The vibration is back again - starting from 70mph ,now down to 50 mph, I can fell pulsating when breaking from those speed - under 50 is ok,
mechanics cannot find a possible solution;
was this a common issue with zimerman amg break rotors?
Don't know of Zimmerman having issues but I will say my wifes W204 seems to warp rotors fairly quick too, I've always chocked it up to her braking style.
Maybe toss on a set of brembo 2 piece and see what they do. I tossed a set of girodisc on mine and never an issue and i have about 3k miles on them now.
It honestly sounds like warping rotors either from heat or uneven braking from calipers, something that is causing some drag to present an excess heat and cooling cycles.
But if it's warped rotors even at low speeds if you hit the brake hard you should feel the lovely shudder and vibration steering wheel feel so to speak.
W204 C63 Coupe, W166 ML350 BlueTEC, 928GT, C5 Z06 & IS300 race cars, EQE 4Matic+ on order
Warped (very likely front) rotors 100%. When you warp one-piece steel rotors that is exactly what happens. And no, just because it doesn't happen below 50 mph does not mean that it isn't the rotors - in fact, that is exactly what happens. Metal expands when heated - when they are cold they are fine. When you start putting some heat into them - as in a stop from 50 mph or higher - the steel expands, and unlike with a two-piece floating rotor where the ring is separate from the hat and can expand radially in both directions (up and down), a one-piece rotors can't do that because the hat is part of the same piece of metal (which it is also in contact with the the wheel and hub assembly which essentially act as a big heat sink) and the metal expansion is uneven resulting in portions of the ring part of the rotor bowing out laterally. When it cools off the metal shrinks and a cold rotor looks perfectly fine.
There is a camp that says rotors rarely warp unless at end of life with heavy, repeated track use. They say that it is more likely uneven brake pad deposits on the rotors from continued light braking on the street.
My wife's explorer gets this due to her driving style and I occasionally go out and do braking runs and it goes away for 6 month until it builds up again. I do 6-10 runs with 100% braking from 55-20 with 20-30 seconds between. These pads don't like heat so the braking fades quickly, but the rotors get cleaned.
12 C63BS Magno Alanite Grey, 22 X3M Brooklyn Grey, 08 BMW E93, 22 Ducati Desert Sled, John Deere 3R
I would try one of the brake bedding in procedures and see if it helps your issue https://www.powerstop.com/resources/...-in-procedure/
While uneven pad material build-up can most definitely cause vibration when braking, that particular cause of vibration does occur at all speeds (as opposed to higher speeds only) as the rotors have uneven pad deposits, and is furthermore very easily remedied by an "Italian tune-up", i.e. several hard stops from higher speeds which is enough to scrub away any such deposits as you have yourself discovered.
Another thing that warps rotors is taking the car through a car wash (or washing it yourself and spraying water on the wheels) when the brakes are still hot. Works every time.
I have personally easily gone through several hundred rotors and twice to possibly three times as many pads on my various cars over time (the vast majority of which have seen at least some track use and have gone through numerous both aftermarket and OEM rotors and pads) - not to mention that at the P-car shop we probably replace ~40 rotors a week as we are one of the authorized PCA tech inspection centers and cater to a lot of track junkies - so all of the above is pretty much as statistically significant as you can get. Last but not least, the saying that you get what you pay for holds 100% true. A C63 is a heavy and powerful car that is quite hard on the brakes. Cheap rotors and pads may work fine on your grandparents' Toyota Tercel - and they even work on my old ex-Honda Michelin Challenge Civic race car on which we just replaced the read drum brake shoes for the first time since 2004 - but not on a 4000 lb, 500 hp beast once you get it up to speed.
There is a reason that most heavier cars with large diameter brakes use a 1.5pc/2pc rotor setup. The reason is the larger rotors will "warp" very easily even with moderate use. If you used the Zimmerman 1pc rotors you will likely always have this issue. There are also a number of bushings up front (tie rods will be worst for shuddering) that wear out and can introduce some front end wobble (tie rod ends will allow the wheels to shake laterally under braking as an example, but your fresh rotors solved the problem it seems).
Your best bet as already suggested is to use the p30/p31 rotors because they should have been spec'ed for all c63's due to the rotor size. You should also service your calipers as a sticky piston can easily accelerate these issues.
A shot in the dark but I have experienced over torqued lug bolts or unevenly torqued can cause an issue with one piece rotors so just throwing that out there in case it could be a factor.
Dogtag114 (09-08-2022)
Which Hawk pads? HPS work great with no issues. HP+ could possibly warp them depending on use. DTC-70s will definitely warp the rotors the moment you warm up the pads (they have no bite whatsoever when cold).
When mounting new discs it is important to make sure the wheel hub flange is shiny and smooth, I use sand paper for this then apply light smear of copper coat across the surface to stop corrosion.
Make sure the back of the wheel mating face is also cleaned up and torque up the wheel nuts.
I dont get all hung up with break in procedures just drive it normal but allow longer stopping distances for 2 weeks.
If you are doing some sort of break in procedure which involves getting the discs abnormal hot while still new you could very likely run in to warping issues.
Plus 1 for above comment.
HELPPPPP
2023 update -
After replacing front caliper, Rotors, and Pads. front right wheel bearing. The vibration went off during normal high speed cruising. However, the break vibration & pedal shudder can still be flt when breaking above 50 mph. most noticeable at 50mph. incredibly annoying. Any other ideas from yall. please throw them my way
Received 2,836 Likes
2012 P31 C63 Coupe Trackrat, 2019 GLE63S Coupe Beast
If all that brake hardware and wheel bearings were changed, you’re feeling something else and confusing it with brake vibration. I’d start looking at control arm bushings, ball joints and other suspension components next.
Xavier Smith II (02-07-2023)
