Headbolt DIY question (139k Miles)
CLS63 AMG, E92 M3
Hey guys, just had a question regarding the one by one method headbolt change that I am about to do.
My car has 139k miles, a tech had suggested I spray the headbolts with penetrating oil (wd40, pb blaster) and let it sit overnight before trying to remove them. Is this necessary? will the penatrating oil even soak into the threads since the headbolts are usually sealed tight.
But I think the issue with these is that the corrosion eats into the bolt itself and weakens it, not that the bolts get seized to the block or head. So if you have that issue the spray isn't going to resolve it.
Drifter2090 (09-14-2022)
CLS63 AMG, E92 M3
Can't hurt. If the bolts are corroded it will soak into the corrosion and break it up.
Hi I would recommend some form of grease/oil film to go on the shanks of the new bolts just to stop any corrosion from forming due perspiration and manual handling of the bolts, what I am thinking is dont put them in dry on the shanks.
The bolt is surrounded by air in the bolt hole (head) and no the anti freeze does not and should not get in to the area around the head bolts, if it does you have the start of a bigger problem.
Drifter2090 (09-15-2022)
CLS63 AMG, E92 M3
Hi, I was meaning the acid from sweat on your hands at assembly can cause corrosion on metallic parts ie head bolts, this is why I was recommending assemble the head bolts lubed not dry would be best practice.
Drain your coolant from the block (drain on each side) and make sure you suck all the coolant out of the threaded bolt hole in the block before threading in the new head bolt.
No, the head of the bolt is sealed on the mating surface. Even if it wasn't the threads are pretty far down. You'd need quite a bit of penetrating oil to get down to the threads.
Oh I see what you mean, I was going to wear new gloves when handling them but I also thought the new bolts came with that thin thin layer of white/grey coating that pushes out when tightening? What kind of lube should I use on the shank (assuming that's the non threaded area above the threaded?)?
The cavity surrounding the shanks where the bolt passes down head and will have air gap around it.
I am not sure if the holes at the bottom of the block through in to the water jacket but be very surprised if they did as that is an old technique and require special sealant to be applied to the threads on the bolts to stop water getting in to the engine.
So hence my statement no the the bolts are not surrounded by water.
Received 2,836 Likes
2012 P31 C63 Coupe Trackrat, 2019 GLE63S Coupe Beast
The thing is and I am 100% sure that the head bolts are not surrounded by water when in use.
![](https://cimg0.ibsrv.net/gimg/www.mbworld.org-vbulletin/432x270/21f3a1b4_c2e7_41eb_8b59_145c56a84419_01a89cf0881e89754f7f9bf3e45a5725fe6858e9.gif)
My apologies I am wrong I will have to do some study and eat some humble pie, please disregard any information I posted as not applicable to this engine type.
Yes new owner W204 C63.
All the best with your head bolt change out.
The following 3 users liked this post by NZ-Merc:
@Drifter2090 Just follow the wis for removal/install of a cylinder head on details about the bolts. They're provided in a few HB threads already. You don't use any substances on the bolt shank OR threads and they will already have sealant on the head mating surface.
Drifter2090 (09-16-2022)
CLS63 AMG, E92 M3
CLS63 AMG, E92 M3
@Jasonoff Just completed the passenger side with no issues! Just a question, even with the coolant drained and using a fluid extractor after removing the lower bolts, some coolant still got out. Should I do a first start then oil change? or oil change then do a first start? Also is there a break in period for the new lifters?
