C63 AMG (W204) 2008 - 2015
After new air boxes, car starts runs for 3 seconds then dies
Old Dec 6, 2022 | 10:20 PM
95gsrturbo's Avatar
2000 Acura NSX, 2012 C63 P31 (gone and not forgotten), 2015 C63 507
I installed carbon fiber ROW style air boxes for decor. They have the same inlet as ROW boxes which I already had on.
Yes they are just cosmetic but that's what my car is for. I don't track it.
Took out AFE filters and washed them like usual, and when I put them back in, I swapped to new CD airboxes.
I'm wondering what could have gone wrong
1) I was SUPER careful and sensitive with the MAF sensors.
2) the new boxes don't use clips but rather an Alllen screw to hold everything together, and yes used the same original rubber gasket to seal
-Any suggestions as to what's wrong?
-Is it possible the MAF sensors are Right and left? (I already checked to make sure they aren't upside down)
-is it possibly bc of the extra air space in the airbox where my hand is?
Attached Thumbnails After new air boxes, car starts runs for 3 seconds then dies-20221206_221401.jpg   After new air boxes, car starts runs for 3 seconds then dies-1670383055755.jpg   After new air boxes, car starts runs for 3 seconds then dies-1670383078202.jpg   After new air boxes, car starts runs for 3 seconds then dies-1670383114051.jpg   After new air boxes, car starts runs for 3 seconds then dies-1670383127507.jpg
After new air boxes, car starts runs for 3 seconds then dies-1670383185015.jpg
Old Dec 7, 2022 | 01:28 AM
BHimself's Avatar
C63 AMG
Are those JL Motoring's boxes with a "custom" AMG badge, or did it come that way?
Those really look good!
Asking the Dumb question, but have you tried restoring back the OE airboxes?
Changing these things out is generally pretty straightforward, all plug & play, and no coding/adaptations required.
As long as there's a good seal around the box the car shouldn't care and the few extra cubic inches where your fingers were shouldn't make any appreciable difference.
So, in my mind, the easiest test is to go back to stock and see if anything got damaged in the process (MAF sensors).
Cheers,
Old Dec 7, 2022 | 03:30 AM
95gsrturbo's Avatar
That's what I did tonight
Have a small kid going to school tomorrow so I don't want to wake him or the whole neighborhood.
I'll check tomorrow and hope that everything runs fine as I'll need a car
Then try again later
I'm 99% sure there was a total seal
I'm 100% sure I had the MAFs installed correctly bc I triple checked them
I was also super careful when removing and reinstalling them the only thing that I have a question with is that I may have clamps down on them too tightly with the Allen screw
Old Dec 7, 2022 | 03:32 AM
95gsrturbo's Avatar
I got the boxes used on here
Honestly I'm pretty sure it's an EBAY badge that goes on the back trunk... Just used here
Old Dec 7, 2022 | 05:28 AM
hachiroku's Avatar
SPONSOR
2007 Mercedes E63 AMG
MAF sensors are the same left to right. the only difference is one side to the other the sensor is flipped around which is ok since left to right they're mirrored.
do you have any engine codes?
__________________
-BARRY
​​​Follow us on instagram @eightysixtuned
https://www.eightysixtuned.com
Old Dec 7, 2022 | 08:40 AM
95gsrturbo's Avatar
Update.... With CEL.... See below
Old Dec 7, 2022 | 02:47 PM
eightysixtuned's Avatar
W211 E63 AMG
The only thing i can think of is a wire harness ground has fallen off or your fuel pump has failed. I haven't tried it, but my assumption is that the engine will run with the MAF sensors unplugged/failed. Just won't rev without stuttering is my guess.
Could you check fuel pressure at key on with STAR/DAS?
Old Dec 7, 2022 | 10:22 PM
95gsrturbo's Avatar
Update:
Got up this morning early... Took everything off and put it back one... ONE SIDE AT A TIME.. to see if it was driver or passenger side issue... Well .. it was neither...
After putting both on together... Started fine a few times... Trip around the block... INITIALLY was a bit choppy in comfort , sport and S+ we're fine...
Drive it to work... 10 mins in CEL
Pulled a code.
I get a P0101 (MAF sensor)
Could be I messed up the MAF, could be a vacuum leak.... Could it be the boxes don't sit flush or that they don't sit well in the rubber intake? It is a tight fit?
The MAF look clean... Should I just get new ones to be safe?
Car drives now at least.
Old Dec 7, 2022 | 11:39 PM
INS1GNIA's Avatar
'13 C63 AMG P31
Also make sure the y intake in the back is latched down fully. Might have wiggled a little loose.
Old Dec 8, 2022 | 03:24 AM
95gsrturbo's Avatar
Does this just pop off? No screws/clips?
Old Dec 8, 2022 | 06:54 AM
Why Vegas's Avatar
AMG GTs & w204 C63
If you look on sides there’s a few clips. Usually if those arent sitting properly they will cause the exact issue you are describing. Happened to my brother on his CLK55
Old Dec 8, 2022 | 07:59 AM
95gsrturbo's Avatar
I can't say that I didn't really do anything to affect this except to jiggle the air box cover into it....I would assume the best thing to do would be to just push down it to ensure it's in place?
Old Dec 8, 2022 | 11:33 AM
KLinNBC's Avatar
2009 SL63 AMG
Check that it's seated by trying to jiggle it: it shouldn't move at all. When properly seated and clicked in it's very solid. You don't want to push down until you're sure it's aligned correctly. If it's really loose and off the intake opening pushing too hard could break tabs and or damage seating surface.
Old Dec 8, 2022 | 12:15 PM
W211 E63 AMG
P0101 equates to "Mass or Volume Air Flow A Circuit Range/Performance". this occurs when the sensor is measuring out of configured range defined by the computer for diagnostics purposes. this code is triggered with supercharged tunes due to the excess of airflow. remapping of the MAF sensors are required to prevent this code as more airflow is being seen across the MAF sensors. diagnostics and sensor checks for the ME 9.7 are very accurate.
since this is new for you and your tune (factory or aftermarket since that hasn't changed recently) has never thrown this code before, i'd possibly recommend cleaning your MAF sensors, but this code doesn't necessarily mean your MAF sensors are bad. could mean they're bad, but also could be other factors. I would possibly try swapping out known good MAF sensors if cleaning your existing ones don't help. a vacuum leak or unseated airbox wouldn't generally cause this code as it is mainly if the sensor is dirty thus reading low or if the sensor is reading excessive airflow. enough that only something like a supercharger provides.
Old Dec 8, 2022 | 01:04 PM
BLKROKT's Avatar
2012 P31 C63 Coupe Trackrat, 2019 GLE63S Coupe Beast
You have an air leak. Your MAFs don’t just both spontaneously go bad at the same time.
Check the air box to y-pipe and y-pipe to intake manifold connections. Sometimes the rubber gets folded in or otherwise distorted creating leaks.
Old Dec 8, 2022 | 09:13 PM
95gsrturbo's Avatar
Great thought. Thank you
Old Dec 8, 2022 | 09:18 PM
95gsrturbo's Avatar
Originally Posted by eightysixtuned
P0101 equates to "Mass or Volume Air Flow A Circuit Range/Performance". this occurs when the sensor is measuring out of configured range defined..... that only something like a supercharger provides.
Thank you for your response and help !!! 🙂
Old Dec 11, 2022 | 01:11 AM
Ludedude's Avatar
2014 C63 Coupe
Yeah, those are ***** sometimes and next to impossible to see when they're not seated right.
Old Dec 12, 2022 | 10:27 AM
95gsrturbo's Avatar
Update again.
Removed boxes and reinstalled
Cleared the codes
Drive for 3 days... All good
Posted here that it was fine...
Drive to the pharmacy 1/4 mile from home aaannndd code is back. FML
Back at it tonight I guess
On another note ....(butt Dyno related)
After I cleaned my air filters I hear more snap crackle pop when I slow down and I dont have a crackle tune.
Old Dec 12, 2022 | 07:12 PM
W211 E63 AMG
Update again.
Cleared the codes
that means you have a vacuum leak, PCV is bad, or something is introducing extra air into your system.
