Replacement bottom seat cover
I have a 2014 with the black MB tex and fake Alcantera in the middle. Is it possible to find a new set cover? I have a few rips in MB tex part which will only get worse over time. I tried searching here but only found childs car seats:
https://mbparts.mbusa.com/v-2014-mer...e--6-3l-v8-gas
https://mbparts.mbusa.com/v-2014-mer...eat-components
You need to specify coupe or sedan, as well as these parts should be ordered from the dealership parts dept directly to ensure the fabrics/leathers/finish are correct. these online sites will likely get it wrong.
chassis (01-06-2023)
here you go.
That's the part number 204-910-03-08-9D88
https://mbparts.mbusa.com/oem-parts/...LTA4LTlEODg%3D
To make sure try to find the tag which is located in the crease.
or compare it to some ebay listings. Look at those two below and scroll through the pictures to make sure the part number matches the cushion you are looking for.
Ebay listing
Ebay listing 2
Ebay listing
Ebay listing 2
Hi,
The lower seat can unbolt with 2 bolts leaving all the seat frame and back piece behind in the car, the 2 bolts are at the front and hold saddle clamps going around the round seat frame ones these are un done just lift the front enough to get your hand in and un plug 1 wiring plug.
With the wire plug un done just lift out the seat base,
The seat cover I have not removed just looks to be clipped over the seat base lip.
Please let us know how you get on and cover swap process also cost would be good thanks.
Thanks,
Yes That is exactly how to remove the lower seat cushion and can be done with out unbolting the seat from the floor.
Very good price for the new cover, mine is black leather and more expensive.
I was investigating swapping the cover and padding over to the other seat that way even up wear on the leather bolsters and also the foam bolster would be in new condition if I could swap them also.
I did notice the passenger side has an occupant sensor and just not sure if it sits in top of the foam pad or is sown in to the leather cover at this stage.
Yea I noticed the price difference with the leather. The only time I'm glad I didn't have the leather. On the other hand, this vinyl seems really thin and I feel like leather would not have torn as easily.
AMGSPY (01-18-2023)
